586,080 active members*
3,655 visitors online*
Results 1 to 3 of 3
    Jan 2007
    1332
    Procunier Tapping head
    I have tapped 10s of thousands of blind 4-40 holes with my Procunier 1E tapping head with excellent results on both manual and CNC mills. A nice thing about using the Procunier on my Tormach CNC mill is that the code is so simple 2 lines:100% downfeed rate, no dwell, and retract at 200% downfeed rate. Also I tap aluminum 4-40 with a Balax form tap at 1200 rpm so fastand and no chips. With the cushioned double-cone clutch small taps i.e. 0-80 work great. In addition I installed the Pro-Quik quick change tap holders so changing tap sizes is just a snap away. http://rockford-ettc...Pro-QuikTap.pdf I just enter the z height for each tap size in the tool table and quickly swap out tap size during tool change. I made a bracket with anti-rotation rod and TTS quick change tooling so changing the entier Procunier tap head on my Tormach is quick and easy especially with the power drawbar.
    Don
    Attachment 407294
    Attachment 407286
    Attachment 407284
    Mar 2009
    1863
    Re: Procunier Tapping head
    I have a TapMatic 30X and a 50X. They’ll go in at a programmed speed and come out 75% faster.
    I have developed a program to tap holes on my 1100 and I have done threads as small as 2-56 right in the spindle with the ER-16 TC tapping head.
    Jan 2007
    1332
    Steve,
    2-56 blind holes with the ER-16 TC tapping head? I also have Tapmatic 30x and 50x. Got to love those rubberflex collets and pesky wrenches to change tap sizes on the tapmatic. I will take the Procunier any day over the Tapmatic especially with small taps and blind holes.
    Don
  1. using a procunier tapping head
    By toyshop in forum Tormach PathPilot™
    Last Post: 01-03-2017, 04:32 PM
  2. Procunier Tapping Head ... last
    By whagkangmakulet in forum Tormach Personal CNC Mill
    Last Post: 06-03-2015, 07:57 PM
  3. Multi-tap procunier head?
    By krakenatwork in forum Uncategorised MetalWorking Machines
    Last Post: 06-09-2013, 11:15 PM
  4. Procunier tension compression tapping head
    By MFchief in forum Tormach Personal CNC Mill
    Last Post: 09-07-2011, 02:58 AM
  5. Reversing Tapping head vs Tension/Compression tapping Head
    By apeman88 in forum Tormach Personal CNC Mill
    Last Post: 01-25-2011, 03:39 PM
