586,072 active members*
4,512 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Acramatic 2100 shut down procedure
Results 1 to 3 of 3
    Hi everyone,
    I am working on A 2100 control for a friend and have the chassis out of the machine. I have boot windows to see if the machine passes diagnostic and now want to shut down the control. Is there a Keyboard command to shut down windows. Or a way to get to the start menu and select shut down?
    Thank you for the help!
    Dec 2006
    584
    Re: Acramatic 2100 shut down procedure
    It depends how you have it set up. Control,alt and delete if you are in windows only, master stop input if you have the I/O hooked up. You could also shell out to DOS and shut it down.
    MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Mar 2008
    285
    The answer is only a phone call away....
    Fives Cincinnati Technical Support is 1-859-534-4750 We are the same group that has supported this product in the US and were formerly Mag-Cincinnati; Unova-Cincinnati; Cincinnati Machine; and Cincinnati Milacron.
    Hours 8am-5pm EST (Lunch Noon-1pm EST)
    Best Regards,
    Greg Wood
  1. proper shut down procedure for vm16
    By dkirby in forum Milltronics
    Last Post: 12-16-2017, 09:24 PM
  2. Proper Startup/Shutdown Procedure for Kflop
    By MadTooler in forum Dynomotion/Kflop/Kanalog
    Last Post: 07-11-2016, 07:55 PM
  3. acramatic 2100
    By mtcalireza in forum Cincinnati CNC
    Last Post: 01-25-2012, 11:38 AM
  4. NEED ACRAMATIC 2100
    By nikolamkd in forum Cincinnati CNC
    Last Post: 01-12-2012, 09:53 PM
  5. Acramatic 2100
    By clayman in forum MetalWork Discussion
    Last Post: 02-19-2011, 12:29 AM
