586,061 active members*
4,456 visitors online*
    Oct 2011
    19
    Oring groove tool
    I have been searching for a .125 oring groove tool to tun an oring groove on some stock . does anyone have any suggestions or part numbers for the holders and inserts . all of the tooling places I have talked to had no idea and kept telling me I need an end mill .
    Dec 2013
    5717
    Re: Oring groove tool
    For a lathe, grooving tool, like a parting tool. or just use a 0.125 wide parting tool.
    https://www.google.com/search?q=groo...w=1815&bih=952
    Jim Dawson
    Sandy, Oregon, USA
    Mar 2010
    1852
    I think what you are looking for is something like in the picture below. This one is made by Valenite. The problem with these is that they are only good for one diameter of groove because the support section must match the groove. This one is for about a 2.5" diameter groove.
    Check with the major tool supplies like Valenite, but you might want to use a grooving tool with some taper on each side to clear after cutting.
    Good luck------Mike
    Mar 2010
    1852
    Found this image and it is a Sandvik.
    Mar 2017
    314
    Quote Originally Posted by billwann View Post
    you need a new tooling vendor
    and this thread needs more blueprints- with dimensions
  1. Milling an Oring Groove
    By mark029 in forum GibbsCAM
    Last Post: 03-20-2016, 09:09 PM
  2. oring groove
    By juniormachinist in forum Mechanical Calculations/Engineering Design
    Last Post: 07-08-2012, 04:02 AM
  3. circle milling oring groove
    By bigmousepusher in forum Dynapath
    Last Post: 04-14-2010, 09:18 PM
  4. Q: Best way to cut small oring groove?
    By Deviant in forum MetalWork Discussion
    Last Post: 06-23-2005, 07:38 PM
  5. cutting oring groove
    By fastolds in forum BobCad-Cam
    Last Post: 06-17-2005, 08:26 AM
