Originally Posted by
rwskinner
Spindle motor - 15 hp Baldor motor.
Gear Change Mechanism - Pneumatic Solenoids and rollers.
Ballscrews - So I made 1 turn of the ballscrew moved me 0.394" so I guess it is metric screws at 10mm pitch.
I took apart the lube pump and cleaned it all out and got it working. When I press the solenoid manual button, pressure jumps up to about 180# and stays there for a few seconds then drops to zero. Not see much lube at the ways.
I guess I might as well replace all the lines and clean the manifolds while I'm in there. Anyone know what size lines those are and how much I need?
New problem, since I sealed up the lube pump, one of the air cylinders on the speed changer is blowing out the stem seal. Cylinders look like they are crimped together but I hadn't tried to take one apart yet.
Still cleaning!!!
Richard
