586,121 active members*
3,523 visitors online*
Results 1 to 6 of 6
    Mar 2007
    242
    In the process
    I have purchase a X-2 mini mill and am in the process of converting it to a CNC machine.
    The only software for any of this that I currently own in a copy of MACH 3 as the machine is not done yet, I have not used it either.
    Some type of drawing program would be really handy right about now as I need to draw up the designs for the motor and bearing mounts. Will dolphin do this and than convert it for the MACH 3?
    I'm a Hobbyist so at this point cost will be a concern.
    Smitty
    Yes not only will Dolphin handle all your geometry and cam needs, we have all Mach posts completed. We shake very well with Mach. Last but not least, we support hobby customers just as much as machine shop customers so we do help out with price quite a bit.
    Rodney Hill
    Mar 2007
    242
    Ok, which one?
    I will not be making any really complex parts in the near future. Text, Counter bores, Holes, etc.
    Which Mill package would you recommend?
    Smitty
    I'd reccomend Level 2, then you can always bump up if need be. That's the safest bet.
    Rodney Hill
    Mar 2007
    242
    How much?
    I looked at the site and the one listed for Hobby is level 1 I believe at $195 and the level 2 is $595, is that correct?
    What does level 2 buy me? As I am new to all of this, I need plain English not machine speak.
    If I start with the level 1 will the level 2 price upgrade be $400?
    Smitty
    The differences between 1 & 2 are dramatic compared to the differences between 2 & 3. There's many features that are added. I will send you a PM shortly.
    Rodney Hill
  1. Pro/E Pro Engineer Process to G-code
    By saris in forum PTC Pro/Manufacture
    Last Post: 11-30-2017, 10:07 AM
  2. Tig Process ??
    By millman52 in forum Welding Brazing Soldering Sealing
    Last Post: 04-30-2007, 07:41 PM
  3. Automating the Broaching process
    By Donald in forum Mechanical Calculations/Engineering Design
    Last Post: 10-20-2006, 10:09 PM
  4. Error: Could not process surface!
    By Swiss in forum OneCNC
    Last Post: 07-27-2006, 03:00 PM
  5. What kind of process controls does MC have?
    By HuFlungDung in forum Mastercam
    Last Post: 05-29-2003, 04:31 AM
