586,047 active members*
3,931 visitors online*
Results 1 to 7 of 7
    Feb 2010
    60
    Simple Aluminum Bars with Rounded Corners
    6061 Aluminun Bar
    0.75" x 0.125" X 14"
    Bar may be extruded with rounded corners on sides, or not, the side rounding is preferred, but not important.
    Ends rounded at 0.045 radius on all 4 edges. No sharp edges on whole part.
    I get a good finish on these using dish scrubbing pads, and would like a finish like that.
    Tolerance 4 thou.
    This is for a patent pending medical device. Very much like an Orthopedic. The final product is worn on the body presses against fabric, so I want to avoid damage from sharp corners.
    Quantities to quote:
    100
    1000
    5000
    Sep 2009
    135
    Re: Simple Aluminum Bars with Rounded Corners
    Do you have a drawing of the item? You can send it to [email protected].
    Sent from my SM-G955U using Tapatalk
    Dec 2018
    PM sent...
    Mar 2008
    22
    PM sent
    Thank You
    Matthew Schindler
    Micro Shaped
    [email protected]
    Jun 2005
    95
    Pm sent ...
    Sent from my SM-J320R4 using Tapatalk
    Feb 2010
    60
    I have some changes to my quote.
    This is not a high precision part. When in use, all sides will be touching foam padding, or fabric, so I just need the corners rounded as to not tear into the fabric. 0.045 radius, but 0.04 or 0.05 is ok too. Round all edges, and corners.
    Attachment 407538
    Quantities, lengths vary.
    100 pieces:
    20, 11"
    20, 12"
    20, 13"
    20, 14"
    20, 15"
    1000 pieces:
    200, 11"
    200, 12"
    200, 13"
    200, 14"
    200, 15"
    10,000 pieces:
    2000, 11"
    2000, 12"
    2000, 13"
    2000, 14"
    2000, 15"
    Sep 2006
    1738
    Quote Originally Posted by bmurph View Post
    Attachment 407538
    100 pieces:
    20, 11"
    20, 12"
    20, 13"
    20, 14"
    20, 15"
    1000 pieces:
    200, 11"
    200, 12"
    200, 13"
    200, 14"
    200, 15"
    10,000 pieces:
    2000, 11"
    2000, 12"
    2000, 13"
    2000, 14"
    2000, 15"
    Pm'd you, if you could just e-mail me with the address I provided, I'll respond with my quote!
    Kind Regards,
    Jason
  1. Increased feedrate, getting rounded corners
    By manyhats2007 in forum Mach Software (ArtSoft software)
    Last Post: 07-08-2014, 01:07 AM
  2. rounded corners when pcb milling
    By jpm000001 in forum LinuxCNC (formerly EMC2)
    Last Post: 04-09-2012, 08:38 PM
  3. square corners getting rounded off
    By SatanKlawz in forum Uncategorised CAM Discussion
    Last Post: 06-30-2010, 02:33 AM
  4. rounded corners
    By jc286006 in forum Uncategorised CAM Discussion
    Last Post: 06-25-2006, 06:04 PM
  5. Rounded corners...
    By saturnnights in forum SheetCam
    Last Post: 02-13-2006, 08:06 PM
