CutLeader supports the foam cutting well now.
Thanks for the automatic avoidance function we developed, user run the auto-seqeunce function, and could get the right cutting movement without any collision.
For some foam cutting machine, the blade could rotate betweem -360~360 only, then after a cutting of a part coundary, we need reset the blade angle for next cut, Cutleader supports this function also, user can specify the reset position along the movement path, and the software would generate reset command for the cutting machine.
Here is the video shows the function designed for foam cutting machine.
https://youtu.be/b1bT_1KIj10
https://youtu.be/bU2WchtWkAE
