586,104 active members*
3,371 visitors online*
Results 1 to 18 of 18
    Jun 2010
    28
    3.5 Spindle wire
    What is the recommended shielded wire from the VFD to the spindle if I have a 3.5kw 220v? I think its 15amp?
    I cant find sh@t on 3.5 spindle wiring.
    Thank you
    Jason
    Re: 3.5 Spindle wire
    McMaster Carr 7777T21
    Igus CF31
    Mar 2010
    621
    I just bought some Igus CF6 14-4 for my new spidle, 20ft. ran me about $80 delivered.
    https://www.igus.com/product/950
    Adam,
    Gecko G540, Rack and Pinion Drives-X and A axis, 1/2-10 5 Start Acme-Z Axis
    4-THK HSR 25 Linear Slides, KL23H2100-35-4B, Power Supply-KL-600-48 48V
    May 2005
    3920
    Depending upon power factor and just looking at input power to the motor, current could easily range from 9 to12 amps. Plus we don’t know if the motor is rated for output power and thus the possibility of efficiency being a factor.
    In any event the NEC requires all electrical motors to be rated with all the data you need. In this case you need the phase current value. It is likely well under 12 amps so 14 gage wire would do. If the current rating approaches 14 amp I’d upgrade to a 12 gage cable. A decent cable suitable for drag chain usage is a bit expensive but worth every penny.
    By the way this assumes running a 3 phase cable to the motor from the VFD. A single phase run requires a 12 gage cable.
    Jun 2010
    28
    Single phase
    Jun 2010
    28
    Perfect, went with 12g.
    Thank you
    May 2005
    3920
    A VFD implies 3 phase wire to the motor.
    Jun 2010
    28
    This is the model I have.
    DZB200B003.7L2A 220 3.7 220V 50/60Hz 0~200V
    0~600Hz 15
    Oops, read back a bit... Got ya
    Jun 2010
    28
    Hmm I already posted this but it didn't take.
    I need to figure out the VFD to spindle and to controller wiring.
    How do I check ohms on the spindle? Its has 1-4 and a grd.
    VFD to spindle from UVW?
    Controller to VFD RST?
    Control has a 3 pin out 1=24v, 2=gnd, 3=0-10v?
    Any insight would be great. I cant find the manuals for these anywhere.
    Thank you
    J
    15362
    You are getting a little carried away with your cable size, these quality cable that most are using 16gage is rated for 20Amps
    Mactec54
    15362
    Quote Originally Posted by JasC View Post
    Thank you
    No point in using 12gage if it won't fit in your plug post some photos of what your spindle or motor connection has, you can't just buy any sort of cable and expect it to work for you
    Mactec54
    Jun 2010
    28
    Its is large and will fit I checked. Second its shielded for this type use.
    J
    15362
    J
    Of cause it has to be shielded for this type of use what is the flex rate of the cable you have ordered this is important also if your spindle motor is mounted on a Z axes
    Mactec54
    Jun 2010
    28
    Its free hanging.
    J
    15362
    Its free hanging.
    J
    So there is no movement with the cable, then you could of used a much cheaper alternative, it helps everyone if the poster gives all the information as to what they are doing type of motor / spindle VFD Etc
    Mactec54
    Jun 2010
    28
    Will do.
    So for the WTF of the day I have....
    Probotix controller, nema34s 8 wire.
    I wired these up parallel correctly per manu. and the controller would not respond, well move the motors. Mach said the motor was moving but nope.
    Pro setup is Bipolar only from a email by the Co.
    I did some juice chasing and it was at the drivers out when I jogged...so I descided to wire them series and they worked...???...
    So the question is what is happening here. I was hoping to use max torque poss on the motors....soooo what am I not getting here.
    Sorry about the dumb questions I had to walk away from this project 5 yrs ago...life.
    J
    Most likely a wiring issue. If they work when wired series, they should work when wired parallel.
    Jun 2010
    28
    Ah ya. The wiring diagram I got wasn't correct.... even had the motors number. Shes moving on 2 axis now. Still have to weld up Y mounts.
    thank guys
  1. Spindle wire components
    By Richmc in forum Chinese Machines
    Last Post: 09-02-2018, 04:40 PM
  2. Replies: 1
    Last Post: 05-03-2013, 12:42 AM
  3. Video to wire 2.2KW SPindle and VFD
    By automationtechinc in forum Automation Technology Products
    Last Post: 08-11-2012, 02:22 PM
  4. Correct wire gauge for 2.2kW spindle
    By cnc3678 in forum DIY CNC Router Table Machines
    Last Post: 10-12-2011, 12:58 PM
  5. Help to wire up a KL2200 spindle
    By cset-racing in forum Uncategorised MetalWorking Machines
    Last Post: 03-10-2011, 01:19 AM
