586,103 active members*
3,304 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > 4020 with drawbar cylinder issue
    Oct 2008
    1632
    Air leaks out the bottom of the spindle when I activate the drawbar cylinder.
    I took the cylinder apart and it had good o-rings but I replaced anyways and clean it all up.
    I put it back together and the same thing happens.
    It appears air comes out of the cylinder's center shaft / stem, and flows thru the spindle.
    Is that by design or do I have something wrong? It doesn't seem like enough for a air blast but I guess anything is possible.
    Sounds more like a leak to me.
    Cylinder opens and closes fine.
    Richard
    Jul 2005
    100
    Re: 4020 with drawbar cylinder issue
    Should be a ~.050 side hole in the push out rod that bleeds air down the drawbar for air blast at tool change .
    It is not a high power blast like some machines with on board air surge tanks.
    Oct 2008
    1632
    Great, Thanks for the info. That's good to know so I don't waste much more time on it.
    Honestly, I didn't think there was really enough air to do much good.
    Richard
  1. Power Drawbar cylinder teardown?
    By yugami in forum Milltronics
    Last Post: 05-11-2018, 02:12 PM
  2. Help selecting air cylinder for power drawbar
    By Middlefart in forum Benchtop Machines
    Last Post: 03-05-2018, 02:48 AM
  3. High Tension Power Drawbar Using 3in Cylinder
    By LacL in forum Benchtop Machines
    Last Post: 08-14-2014, 01:39 AM
  4. Milacron 15VC machining ctr drawbar cylinder
    By ganzelc in forum Cincinnati CNC
    Last Post: 01-01-2011, 05:46 PM
