586,069 active members*
3,561 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > tooling for tough steel
    Feb 2018
    26
    EN24 817M40 4340 ASTM A29 tough stock with a rough finish
    What would you recommend, indexable tips or carbide? this is the part I need to machine, by the 100s:
    6mm (0.236) thick from 8mm (0.315) stock, faced both sides
    mid recess has a 3mm (0.118) rad
    currently using tips but they bang alot on this tough material like it needs a keener edge, probably have stay with tips for the facing - 45mm (1.770) wide cut but thinking about carbides for the sides and recess?
    cheers,
    Dec 2013
    5717
    Re: tooling for tough steel
    That looks like a nasty little part to build. But maybe not so bad with some fixturing.
    Maybe look at some different insert geometry, maybe check with your tool vendor for recommendations. I would definitely use carbide endmills for the profile and interior work. Use the largest carbide bullnose (3mm R on the bullnose) endmill that would make the larger radii. I would rough it out with a rougher, then change endmills for finishing. I'm assuming you have a tool changer on your machine.
    Jim Dawson
    Sandy, Oregon, USA
    Jun 2015
    4154
    hi begin on live tooling lathe, from circa-o90*250 stock ( imagine this setup on a spindle with bore > 90 ); finish on mill
    check attached
    main problem is not tooling, but fixture rigidity and costs+downtime with your actual stock / kindly
    if you go with solid carbides then I'd suggest trying Gorilla mill . Their variable flutes are pretty tough to beat , other than their sasquatch series which is incredible . They are more pricey than a lot of the other tools in the market , but in my opinion they are the best , especially for harder materials
  1. 1/16 end mill in tough steel
    By keen in forum Tormach Personal CNC Mill
    Last Post: 04-05-2010, 07:23 AM
  2. Deep slotting in tough steel
    Last Post: 08-24-2009, 04:45 AM
  3. Tormach on tough steel K600
    Last Post: 05-29-2008, 05:14 PM
  4. Tooling steel you used
    By Wiseco in forum Moldmaking
    Last Post: 11-30-2006, 02:41 PM
