586,070 active members*
3,482 visitors online*
Page 2 of 2 12
Results 21 to 26 of 26
  1. #21
    1227
    Re: HDPE question
    Do keep in mind that the static charge that is almost always induced will likely lead to a film of dust that you will struggle to see through.I have often felt the hairs on my arm raise when it was close to an extractor duct.
  2. #22
    Jun 2017
    369
    Re: HDPE question
    Have you ever tried wiping it down with a Bounce fabric softener sheet? I have to occasionally had to use a Bounce sheet on the cover of my automatic powder measure when reloading. Sometimes it gets a static charge built up & flake powders cling to the cover.
  3. #23
    May 2005
    1662
    Re: HDPE question
    Quote Originally Posted by routalot View Post
    Some wood mills off like grinding dust instead of sawdust or chips. These are 'found' woods which I can't identify but end up in my collection of stock. For the materials I usually cut the acrylic stays clear and in winter this house is dry enough that the cat doesn't like to be petted. There's a ground wire running inside the hose connecting the router to the dust collector, not sure if that makes any difference.
    As far as flame polishing goes, I've only done edges. Some sites suggest only extruded acrylic should be flame polished.
    Anyone who says "It only goes together one way" has no imagination.
  4. #24
    Jun 2017
    369
    Re: HDPE question
    Ok so I tried boiling the HDPE & it's worse than what it was. I'm going to flip it over & try it again.
    I think instead of worrying about machining & then polishing I'm going to use some 3/8" clear acrylic that I already have to create a dust shoe similar to the CNCRP shoe then using an adapter to attach the dust collector hose via a press in fit & machine in a pinch clamp like used on a few dust shoes on youtube. My question is will I be able to screw the threaded insert into the acrylic or would I be better off tapping the acrylic? I'm not sure if the acrylic will expand like the HDPE does or if it would crack.
    Thank you & Merry Christmas
    Gary
  5. #25
    Dec 2013
    5717
    Re: HDPE question
    Tap the acrylic, it doesn't expand at all, much like glass.
    Jim Dawson
    Sandy, Oregon, USA
  6. #26
    Jun 2017
    369
    Re: HDPE question
    I've changed my mind again in stead of reinventing the wheel I just ordered a kent cnc dust shoe with a 3" brush and additional 2" brush as well as a 1/2" spacer.
Page 2 of 2 12
  1. Cutting HDPE Question....
    By iamwill in forum Material Machining Solutions
    Last Post: 01-13-2013, 12:41 AM
  2. Looking for HDPE
    By Hack in forum Glass, Plastic and Stone
    Last Post: 06-10-2012, 10:46 PM
  3. HDPE
    By domar in forum Australia, New Zealand Club House
    Last Post: 12-19-2010, 10:24 AM
  4. I need to buy HDPE
    By jimmycakes in forum Glass, Plastic and Stone
    Last Post: 10-22-2008, 09:34 PM
  5. HDPE
    By cnczoner in forum MetalWork Discussion
    Last Post: 07-07-2008, 01:17 AM
