586,055 active members*
4,311 visitors online*
    Oct 2008
    114
    Blowing Fuses After a Power Outage
    hey folks need some advice -
    After tripping over the mains 240v cable on my JCUT 6090b and hearing it spark at the kettle socket end (machine end) it now keeps blowing fuses...
    Initially was in the 5v-12v transformer (see image 1) at the 3amp glass fuse, but since changing the mains 5amp wall fuse to 3amp thats the one that keeps blowing now on every fire up (soldered a new glass 3amp into the transformer) .
    The kettle socket end did come loose hence the initial spark but is fully inserted now.
    Also whats odd is at the point of power up its the mains 240v live into the transformer that flashed when i power up (which then blows the mains fuse)
    If I disconnect the 240v live into the transformer the machine powers up (vfd and drives are all energised).
    Any help appreciated - i am an engineer but not an electrical engineer
    Attachment 408008
    Circled point "A" is where i now get a flash at power up. Disconnecting the live and neutral here prevents the fuse blow (so drives see power ok)
    , but obviously no power now to spindle control board and smooth stepper
Name:	new wiring - Copy.jpg
    15362
    Re: Blowing Fuses After a Power Outage
    Quote Originally Posted by JQ_Quint View Post
    Attachment 408008
    I would say that the power supply has failed, you have a short somewhere, do you have this wired correct with a Ground wire on the Ground Terminal
    Mactec54
    Aug 2019
    Hi JQ_Quint...
    Can you email me at '[email protected]'
    Thanks buddy...
  1. Two different power supplies keep blowing fuses
    By JoeyJoe in forum CNC Machine Related Electronics
    Last Post: 09-15-2014, 09:42 PM
  2. Blowing 20a fuses!
    By fgwilson99 in forum Community Club House
    Last Post: 04-28-2011, 02:13 AM
  3. KL- 7220 Power Supply Blowing Fuses
    By MRM RCModels in forum Automation Technology Products
    Last Post: 03-17-2009, 03:33 PM
  4. Blowing fuses
    By kaderick in forum CNC Machine Related Electronics
    Last Post: 12-05-2006, 06:34 PM
  5. Blowing the fuses
    By rocks101 in forum Hobbycnc (Products)
    Last Post: 02-26-2005, 10:00 AM
