586,067 active members*
4,790 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > Thinking about switching to Planet CNC
    I'm currently using MACH 3 and am wondering what I need to do to run my programs in Planet CNC? I use a MACH 3 post processor is why I ask so do I need to change the file extension and the g code of the programs for them to be compatible? Or is there a post processor available from Plane CNC ?
    Re: Thinking about switching to Planet CNC
    That would depend on what CAM software you are using.
    Aug 2011
    999
    For Vectric software as well as Deskproto I use the most generic g-code postsprocessors, e.g. for Aspire the gcodearcs-mm. But many others will work as well. Planet-CNC is not that picky about it. You can use the Shark postprocessor as well.
    Box Joint and Dovetail CAM software here: WWW.TAILMAKER.NET
    Ok thanks for the input..
  1. Planet CNC
    By yar20 in forum PlanetCNC
    Last Post: 04-26-2018, 05:31 PM
  2. USB CNC Planet-cnc
    By Pysiek in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-01-2011, 12:20 PM
  3. Thinking of switching to Haas
    By Bwana Don in forum Haas Mills
    Last Post: 10-30-2009, 05:17 PM
