My A axis stops working when I config to slave it to the Y axis.
It works fine and jogs when its independent , I slave the axis to Y and reboot and its dead, remove the slave config reboot and its fine again. I have toggled all the active hi and low settings for the A axis in motor and inputs signals in every combination I can think of with no luck. I have turned rotary to liner movement on and off.
I am using mach3 version r3.043.062 sugested by warp9 for my smoothstepper.
How do I get it to move with the Y axis
