586,035 active members*
3,797 visitors online*
Results 1 to 19 of 19
    May 2009
    10
    Fanuc 10TF System Error
    A friend of mine asked me to look at his Dosan CNC lathe with Fanuc 10TF control. What I found was a undocumented system alarm on the main board. It is displaying a small "o" , not to be confused with the IPL mode indicator of a full sized "O.". I have done some searching hear and Google with no satisfaction. Has any one seen this before? The maintenance manual states any display not listed to replace the main board. Any help would be greatly appreciated.Click image for larger version.
Name:	System Error o.jpg
    Nov 2018
    28
    Re: Fanuc 10TF System Error
    Quote Originally Posted by cmtas View Post
    Do you have photos, upload it.
    Need some clarity
    Sent from my SM-J710F using Tapatalk
    Nov 2018
    28
    Quote Originally Posted by Nil27 View Post
    Need some clarity
    Does screen has any alarm
    Nov 2018
    28
    Does screen has any alarm.
    Give clear photos
    May 2009
    10
    Screen is blank. Monitor is on with only garbage (lines no text). When the fiber optic cable is unplugged from CRT/MDI controller, red lights appear on controller. Otherwise one green light. I did upload pic of main board with "o" alarm displayed.Attachment 408238
    Nov 2018
    28
    If you have backup then try to clear your master and loading Para
    May 2009
    10
    Screen is blank. No response to try to get to IPL mode. pulled battery to clear memory (30 minutes). Always shows small o on 7 segment display on main board.
    Nov 2018
    28
    You have backup??
    Nov 2018
    28
    Is it a small "c" . Confirm it
    May 2009
    10
    Yes I have backup. Confirming it is small "o" not "c".Attachment 408246
    May 2009
    10
    When first booting display shows several different letters very quickly (i believe this is normal), always ends with small "o" as pictured. All segments are working during boot. None stuck on or off.Click image for larger version.
Name:	System Error o-3.png
    Nov 2018
    28
    Hold " - " and " . " On startup.
    And select 3 to clear files.
    Nov 2018
    28
    Nov 2018
    28
    Start with 7 and 15 no. Files.
    After that you should get system label error
    May 2009
    10
    As I said earlier, IPL mode is not accsesable. There is no screen output. Memory clear has been performed several times. I will try again. Be aware this system is Fanuc 10TF with Fapt, I don't know if that makes a difference.
    Sent from my Moto G (5) Plus using Tapatalk
    May 2009
    10
    Please understand I am not at the machine now, so I had my friend do the power up holding the "7" and "1". Then power up holding "-" and ".". At no time did anything show up on the monitor. However I had him try several times and one of the times the 7 segment display showed "6.", this is a ram check error. This only happened one time, then returned to the small "o" all the time. Still no IPL mode,can't do a file clear. I don't know if this helps at all.
    I am thinking of just replacing all the ram chips at this point in time.
    Apr 2009
    1379
    '7' and '9' for ALL CLEAR operation.
    May 2009
    10
    Yes I tried "7" and "9" also, found on another post. About 1 out of 5 times I am getting "b" when holding "-" and "." On power up. Very strange not being consistent. Most of the time it's "o".
    Nov 2018
    i hope eproms servo software are generating this 'o' alarm .try remove it then plug it back or replace with new eproms. otherwise diagnose this alarm by remove ACP board with any spare ACP board if you have.
  1. Fanuc 6T system error
    By salmve in forum Fanuc
    Last Post: 09-10-2020, 07:38 PM
  2. 998 System error on Fanuc 6M
    By david_chen in forum Fanuc
    Last Post: 12-27-2019, 08:18 PM
  3. Replies: 5
    Last Post: 04-20-2019, 02:31 PM
  4. Fanuc 10tF 7 Segment Error Code "F"
    By glbreil in forum Fanuc
    Last Post: 07-06-2017, 12:56 PM
  5. fanuc 6m has system error 402
    By runlean in forum Fanuc
    Last Post: 01-23-2008, 03:59 PM
