586,102 active members*
3,343 visitors online*
IndustryArena Forum > CAM Software > Vectric > Aspire > 2500 circle vectors of varying diameter - long process and mill time
Results 1 to 3 of 3
    Aug 2017
    31
    I've got a .dxf with 2500 circles in it. Their diameter ranges from 1.75mm to 4.4mm.
    What is the best way to make simple holes according to those diameters?
    - creating a drilling path will mean that I need a drillbit specific to each hole diameter, which I don't have...
    - creating a pocket path for all of them with a 1mm bit, means a really long calculation time (about 30min) and then an estimated milling time of 27 hours!!
    - is the smartest way to divide them into groups and create a pocket path for each group so that I can a different bit for each diameter group (meaning one group with a 1mm bit for the 1.75 holes, then another group with a 2mm bit for the larger holes for example)... ?
    I hope my question is clear.
    Thanks.
    Nov 2012
    1267
    Re: 2500 circle vectors of varying diameter - long process and mill time
    Yes, probably the best strategy would be grouping the holes by size to avoid pocketing operations.
    Sounds like you can get by with just two groups: 1.5mm tool for holes up to 3mm in diameter; 2.5mm tool for the rest of the holes.
    Or something like that, depending on which end mills you have available.
    Dec 2008
    3109
    missing info..
    material
    thickness
    hole depth
    manufacturing tolerance (+/- size) use this to sort hole sizes
    - ie use 1.70 or #50 drill for 1.75mm hole
    what machine is being used
    end purpose of job, what it does ( if possible )
    available tooling... what have you got ?
    if tolerance is +/- 0.10mm diameter, I'd drill all holes if possible, then pocket other holes using a cutter that is a little smaller than the smallest hole diameter needed to be pocketed...
    ramp contour would be quicker than pocketing
    2500 is a lot of holes
    say 5sec to drill each hole = 3.5 hrs .... is a lot better than your 27 hrs to drill & pocket every hole.
  1. Boring hole pattern, takes a long long time
    By kvadda in forum Mach Software (ArtSoft software)
    Last Post: 03-23-2015, 10:03 PM
  2. Determining a bolt circle diameter by 3 points?
    By Fastest1 in forum Calibration / Measurement
    Last Post: 11-04-2013, 12:55 PM
  3. What's Causing Inaccurate Circle Diameter?
    By notselrach in forum Vectric
    Last Post: 10-14-2010, 03:12 AM
  4. Change diameter of a circle
    By sansbury in forum BobCad-Cam
    Last Post: 05-04-2009, 11:41 PM
