586,060 active members*
3,566 visitors online*
IndustryArena Forum > CAM Software > EnRoute > setting material to bottom of plate
    Aug 2016
    Post setting material to bottom of plate
    I am trying to make a constant dado using Enroute 6 Pro. My need is to make a dado on two cabinet parts and cut shelves to fit between. I have set up the plate thickness to the material which is .77", and I want the dado to be .375" so when I cut my cross pieces to be .75" shorter than the overall of the cabinet. So I would subtract .375" from .77" getting a depth of cut to .395". I have define plate to the size of the material .77" and clicked button Surface to bottom of plate. All works fine till I have to reboot machine the next day to continue cutting parts. Any ideals on why this is happening?
    Dec 2018
    That's more than likely a machine issue and not an Enroute issue. What is happening when you reboot? Anytime I restart/reboot my machine (Multicam) I have to reset the machine surface.
  1. Setting Z zero at the bottom
    By assadi in forum Aspire
    Last Post: 04-02-2016, 12:34 PM
  2. CNC tries to work from bottom of material
    By dmcgarry in forum PhotoVCarve and VCarve Pro
    Last Post: 04-13-2015, 06:08 PM
  3. Material Top and Material Bottom
    By wdaehn in forum MadCAM
    Last Post: 12-08-2014, 02:13 PM
  4. I am having trouble with the 'bottom of job' setting
    By jharvey407 in forum BobCad-Cam
    Last Post: 08-04-2011, 11:32 PM
