586,055 active members*
4,277 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Controller Cards > CNC USB MACH3 100Khz Breakout Board problem
Results 1 to 6 of 6
    Aug 2017
    4
    CNC USB MACH3 100Khz Breakout Board problem with auto tool probe .not work with the plugin( RnR MOTION plugin).I would ask for instructions on this board??thanks
    Re: CNC USB MACH3 100Khz Breakout Board problem
    Probing does not work properly with most of the chinese Mach3 controller boards.
    Make sure the probing macro you are using does not use the GetVAR() command, as that's often where they fail.
    Aug 2017
    4
    in the Diagnostic window in mach 3 digitize bright continuously picture scheme of connection...
    Apr 2005
    304
    Try to invert active state of probe signal in settings.
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
    Aug 2017
    4
    Quote Originally Posted by ZASto View Post
    this board definitely has a problem
    Jun 2010
    4256
    What Jerry wrote.
    Cheers
    Roger
  1. Mach3 Breakout Board 5 Axes PWM to VFD output problem...
    By netart in forum CNC Machine Related Electronics
    Last Post: 11-06-2017, 04:28 PM
  2. USB BREAKOUT BOARD FOR MACH3
    By JACKY2014 in forum USB, RS232, PARALLEL etc
    Last Post: 07-27-2015, 12:44 AM
  3. CNC Breakout Board, CM-106, Mach3
    By Robiz in forum News Announcements
    Last Post: 10-08-2013, 06:12 AM
  4. breakout board for mach3
    By albaboun in forum Machines running Mach Software
    Last Post: 04-23-2012, 01:43 PM
  5. Am i limited to 100kHz (pps) when using Mach3?
    By Cocacolalover in forum Mach Software (ArtSoft software)
    Last Post: 12-25-2009, 04:06 PM
