586,043 active members*
3,717 visitors online*
Page 2 of 2 12
Results 21 to 27 of 27
  1. #21
    May 2015
    686
    Re: Grounding HF plasma torch
    I'm not saying anything. I just followed the Hypertherm recommendations in the document and a friend donated a very old "star" grounding point and set up my stepper motor cabling very carefully with noise in the back of my mind. Having 24 volt electronic controllers also helps as the higher voltage is less susceptible to noise.
    Rod Webster
    www.vehiclemods.net.au
  2. #22
    15362
    Quote Originally Posted by Bradnicent View Post
    I am using a db 25 parallel port plug from pc to bob (not shielded) ..... I think my main problem is the torch.... if I can find a way to drain emi from it my pc will probably stop freezing
    This would have to be a shielded cable, this would be a good starting point, go for Double Shielded Premium D-sub 25 Position DB25 Male/Female Cables - Fully Populated, Double Shielded
    Your Torch Grounding and connection should be as per the PDF
    Mactec54
  3. #23
    15362
    Are you trying to say that there is a difference in grounding for emi and grounding for electricity? ..... and the must be grounded separately?
    Here is a video for you and anyone else, this is long it starts with the basics and you may get confused or you will end up with a great understanding of Grounding and what it means
    https://www.youtube.com/watch?v=mpgAVE4UwFw&t=46s
    Mactec54
  4. #24
    Jul 2018
    87
    Will a plasma cutter with pilot arc be a better choice regarding emi? .... a recent google search reveals that it reduces emi ...
    https://www.bakersgas.com/weldmyworl...plasma-cutter/
  5. #25
    Jun 2011
    692
    Pilot arc may still have HF start. I think it may be a bit easier to shield than non-pilot arc, as the return path for the pilot arc is in the torch head.
    What you want is blowback start, which I think is always pilot arc. Blowback doesn't use HF, so much easier to deal with as far as EMI goes.
  6. #26
    Jul 2018
    87
    What exactly is blowback and how does it work?
  7. #27
    May 2015
    686
    The arc is started by shorting the electrodes in the torch head then the air pressure "blows back" the contacts apart so the arc transfers to the material
    Rod Webster
Page 2 of 2 12
  1. ESP-150 plasma torch HELP
    By haroutkhaloian in forum Want To Buy...Need help!
    Last Post: 07-06-2016, 02:11 PM
  2. Grounding CNC Plasma Question
    By CptOvo in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 06-27-2013, 04:35 AM
  3. How to wire a new plasma torch to plasma cam??
    By Bradsky in forum PlasmaCam
    Last Post: 04-05-2013, 12:26 PM
  4. Grounding CNC Plasma
    By z28 in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 04-03-2013, 03:36 PM
  5. Replies: 1
    Last Post: 08-05-2011, 08:21 AM
