586,115 active members*
3,398 visitors online*
    Feb 2014
    Post Cimatron IT13 in Windows 10
    I installed Cimatron IT13 in Windows 10. The environment works, but the mouse does not work well on the menus, when I try to select some menu item, it jumps and does not let me select it. I tried changing mouse parameters and it did not work.///// Instalé Cimatron IT13 en Windows 10. Funciona el entorno, pero el mouse, no funciona bien sobre los menus, cuando intento seleccionar algun renglón del menú, salta y no me deja seleccionarlo. Probe cambiando parametros del mouse y no funcionó.
    May 2004
    50
    Re: Cimatron IT13 in Windows 10
    Feb 2024
    Use Windows 10 version 1607 or 1703
    When installing Ciamtron it13, if you select compatibility XP SP2, it can be installed and run.
    Check Windows version
    On the Windows mark -> Right click -> Run -> Enter "WINVER" and enter
    Feb 2024
    I had success doing this on Windows 10.
    There are no problems with everything, including mouse and screen movement.
  1. Cimatron IT 13 and Windows 7 x64
    By molds2014 in forum Uncategorised CAM Discussion
    Last Post: 02-19-2024, 02:43 AM
  2. Cimatron IT 13 on Windows 7 64bit
    By aadonline in forum Uncategorised CAM Discussion
    Last Post: 10-10-2022, 02:38 AM
  3. MACH3- windows xbox wireless - windows 10 64bit plugins not working
    By cabinman in forum Mach Software (ArtSoft software)
    Last Post: 01-02-2018, 04:48 AM
  4. Cimatron E9 file not opening in Cimatron E10
    By vikas123 in forum Uncategorised CAM Discussion
    Last Post: 01-22-2017, 03:24 AM
  5. Windows XP or Windows 2000 better with Mach2
    By Beezer in forum Mach Software (ArtSoft software)
    Last Post: 10-18-2004, 04:08 PM
