586,115 active members*
3,504 visitors online*
    1943
    Stepper motor wire selection
    I'm converting another milling machine to CNC. In the past I've used wire like in the this picture.
    Attachment 408492
    It has a gray PVC sheath, and a low strand count (ie: fewer and heavier strands per conductor), making it not the greatest for flexibility. I think this is something like security system cable or some other application like that where flexibility isn't a priority but everybody sells it as "stepper" wire. I haven't had any real issues with it except that I personally think it looks, feels, and flexes like an ultra-cheap wire. Kind of like a cord on a cheap power tool in cold weather.
    For this new build I would like to use something better. The motors are 6A, so I figure 18 AWG would be good. I'm thinking about using 18/4 SOOW wire but wondered what others may have used. SOOW cable has a rubber sheath and has good flexibility. It is generally what is used on high quality power tools.
    So what kind of cabling other than the gray stuff is everyone using?
    Also decent connector recommendations would be appreciated as well. I'll need bulkhead connectors for the control box I'm putting together, and matching cable connectors.
    John Brannen
    Apr 2014
    215
    I use SY or CY cable (I am in the UK and it may be called something else in your locality)
    It is basically a shielded / braded cable SY has a closer brade than CY
    https://en.m.wikipedia.org/wiki/SY_control_cable
    It will aide in stopping electronic noise. Only ground one side though!!!!!
    As the motors will probably be grounded to the machine.
    As for cable thickness I tend to use 1mm which is good for about 10amps and has a low resistance
    Jun 2010
    4256
    Re: Stepper motor wire selection
    I won't touch 'rubber insulation' any more. It perishes and the whole cable is likely to go up in flames. I remember a 100' extension lead doing that once. In fact, I have just consigned a heavy duty 15 A extension lead some 60' long to the bin for that reason: all perished.
    Cheers
    Roger
    Nov 2012
    1267
    Rubber cables have another problem: they are pretty much impossible to solder (unless you have a freshly made reel of cable straight from the factory). The rubber insulation does something very nasty to copper wire in a very short time.
    1943
    How about this?
    https://www.automationdirect.com/adc...ed/cf6-07-04-1
    In case the link doesn't come through or dies later it is igus cf6-07-04. A bit costly but I won't need all that much.
  1. Connect an 8 wire stepper motor to a TB6560 Stepper motor driver
    By muldoon22 in forum Stepper Motors / Drives
    Last Post: 12-31-2016, 07:26 AM
  2. Stepper motor selection
    By MetalMagus in forum Stepper Motors / Drives
    Last Post: 12-20-2011, 11:31 PM
  3. Running stepper motor wire with router wire?
    By basskitcase in forum DIY CNC Router Table Machines
    Last Post: 02-19-2010, 05:18 PM
  4. Stepper Motor Selection Help.
    By ibuildstuff4u in forum Stepper Motors / Drives
    Last Post: 11-23-2009, 12:15 AM
  5. Stepper motor selection
    By zerodegreec in forum Hobby Discussion
    Last Post: 11-12-2009, 01:49 AM
