What are ath m-codes for the subspindle on a Mazak with mazatrol controlls?
Forward, reverse, sync spindle?
I have manuals for a 640T w/sub spindle, instructions, parameters, etc...but NO M-codes relating to anything sub spindle!! Don't have a sub, so never looked.
All the parameters apply only to Mazalarm, no mention of EIA at all. Sorry I can't help.
Check out G112. Its been awhile but you call G112 that sends commands to the subspindle. G112M3S1000.
I think its a gcode to switch between spindles.
G112 should work (G112M3 or G112M4).... but for M codes, you might also have M303 (normal) and M304 (reverse). For sync codes, its different between Fusion and Matrix ( for example M511, M512, M513 or M511, G110M511 and M512)
It's just a part..... cutter still goes round and round....
I just posted thes in another thread, I'm not sure if these will be the same for fusion.
300 SS "Second Spindle" mode select
304 SS Reverse
305 SS Stop
306 SS Chuck unclamp
307 SS Chuck clamp
358 SS Chuck air blast
511 Main and Second synchronize
512 Due period end
