586,060 active members*
4,328 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Advice on 28" Rotary table drive design
Page 2 of 2 12
Results 21 to 33 of 33
  1. #21
    Dec 2013
    5717
    Re: Advice on 28" Rotary table drive design
    The theoretical rotational accuracy of the system using the flex plate (164 tooth) and a 10 tooth pinion and 10 microstep is 0.011° this equates to a cord length of 0.003'' at the circumference of a 28'' dia circle.
    I maintain that it is possible to achieve zero backlash in the gear train using a stock pinion, possibly requiring some OD reduction of the pinion. If I am wrong here, I will build a zero backlash pinion that will work, at no charge.
    Jim Dawson
    Sandy, Oregon, USA
  2. #22
    15362
    And it will be like a concrete mixer turning, it has to be smooth for 3D printing
    The teeth on these ring gears are not even a true gear tooth profile, are not designed to be used as a gear as such,you should consult with gear manufacturers on how to do this to get zero backlash, I'm sure they would be all ears, without a split spring loaded pinion or gear, it is not possible to have zero backlash, if it was everyone would be doing it
    The problem is with that gear ratio, and if the stepper is using 10 microsteps the motor won't have enough torque to drive it, or if it does won't be able to control it very well
    Mactec54
  3. #23
    24221
    I have some surplus Emerson precision Planetary GBoxes of various ratio's but I think they would be a bit heavier duty than you need, but they are a nice way to go!
    Max.
    Albert E.
  4. #24
    Dec 2013
    5717
    We could argue this for a week with no resolution, so we will just have to agree to disagree. Suffice it to say that I have made a successful career out of doing the ''impossible''.
    Jim Dawson
    Sandy, Oregon, USA
  5. #25
    24221
    Yeah, miracles take a little longer.
    Al
    Albert E.
  6. #26
    15362
    Max.
    He already has some heavy duty parts for the center hub so your gear boxes would not be out of place if the ratios where low enough
    Mactec54
  7. #27
    May 2013
    480
    Two automobile starter pinions on the flex plate, with the backlash taken up either mechanically or with a spring should work fine and provide smooth motion for OP's needs.
    Regarding the gear teeth on the flex plate.. they are good enough. at 164 teeth you almost can't tell the difference between a gear tooth and a rack and pinion anyways. the gear teeth are broached, all at once btw, so i assume the broaches are generated on gear cutting machines but perhaps not.
    btw if you need a cheap rack and pinion, grind the welds off the flex plate and cut the gear and bend it straight. you probably want to temper it again at 500F afterwards, or bend it while its hot.
  8. #28
    Nov 2018
    53
    Thanks all! So much great advice. And I appreciate you thinking out of the box.
  9. #29
    15362
    Quote Originally Posted by Eldon_Joh View Post
    That's the most ridiculous thing you have posted (nuts)
    If you where to straighten out the ring gear, the teeth would close up, and there would no way be able to keep it in pitch
    A piece of rack that size would cost around the same as a flex plate
    Mactec54
  10. #30
    May 2016
    316
    I've been following this interesting thread, especially since I'm at the beginning of a build using a Bell-Everman loop-track type of system.
    If the starter & flexplate doesn't work out to satisfaction, maybe buying a T5 belt and bonding it inside out to a disk of some sort would work. Turn the disk OD so the belt is a snug fit and glue it in place. Make a couple rims for belt tracking (i.e. sandwich) and then get a larger belt that loops around the disk and a small T5 pulley on the stepper or servo. An idler pulley to ensure more tooth engagement on the motor pinion and belt tension.
    A 28" turntable works out to about a 450 tooth 'pulley' if my math is anywhere close. Brecoflex recommends 30T minimum pinion (with idler backbending), so that works out to 15:1 reduction. If you need more, use a double-reduction and switch to a GT2 profile for the primary reduction pulleys to minimize backlash.
    A 450T belt is about $17 from B&B, and figoure about $20 for a longer one to wrap around the pinion. Plus the pulleys and GT2 stuff if ou need double reduction.
    I think this would be quieter and smoother than the gear arrangement.
    I seem to recall Mke Everman mentioning in his huge thread that the trapezoidal tooth profiles engaged each other better then curvilinear in a belt-on-belt situation.
  11. #31
    May 2013
    480
    a flex plate is like 10$ at a junk yard.
    as for how much the teeth close up, not enough to matter. yes i know this from experience.
    regarding ridiculous things you post, telling someone incorrect parameters burned up their spindle when it worked for them.. for 2 years! is pretty funny.
  12. #32
    15362
    Are yes but if they had the correct Parameters it would not of burnt up, if your spindle has burnt up and it could of been avoided, that would have very little to do with funny (nuts)
    Mactec54
  13. #33
    24221
    Various from 5:1 to 100:1, various duty ratings.
    Al_The_Man
    Albert E.
Page 2 of 2 12
  1. Advice on Bearing for 24" Rotary Table?
    By disneytoy2 in forum Linear and Rotary Motion
    Last Post: 12-13-2018, 04:44 PM
  2. Pros and cons of rotary table sizes: 6" vs 8"
    By dbruins in forum Tormach Personal CNC Mill
    Last Post: 01-09-2015, 08:59 PM
  3. 6" or 8" Rotary Table for 4th axis on G0704?
    By bogiestl in forum Benchtop Machines
    Last Post: 01-31-2012, 03:33 PM
  4. What size stepper to drive a 10" rotary table?
    By fido in forum Stepper Motors / Drives
    Last Post: 11-12-2008, 12:57 PM
  5. Replies: 4
    Last Post: 05-17-2006, 11:19 AM
