586,512 active members*
3,417 visitors online*
Results 1 to 6 of 6
    Jan 2004
    258
    weldon flats?
    Does anyone have the specs for weldon flats? I need to put them on a solid model. We need these on the print to send to the porting tool manufacture. I know that they allready know the specs for the flats but we need to have them on the print for ISO.
    Cncwhiz
    Jan 2007
    103
    ya, i've got the specs.
    i don't know how to post them pm me and i'll e-mail them to you.
    you can get them out of machinest handbook too. but it's not complete.
    i have the spec sheet from the weldon tool co.
    i'll scan the spec sheet and post it here tommorrow (if i can figure it out)
    then it will be here if anyone else needs it.
    Jan 2007
    103
    here are the specs for weldon flats.
    hope this helps
    but please note: there are different sizes for stub length endmills
    which are not on this sheet.
    Attached Files Attached Files
    Jan 2004
    258
    cb1,
    Thanks for the info. I looked at your previous posting and went to "weldon" and downloaded their product catalog in pdf. It has the weldon flats listed and a chart by size. Do you want me to attach or pm you the pdf? Thanks for the info.
    cncwhiz
    Jan 2007
    103
    you should post it so if someone else ever needs it, its there.
    thanks.
    Jan 2004
    258
    I am trying to "upload" the file for everyone's use. It is telling me that it is complete but does not show up?
  1. Weldon vs Collet
    By dhiruj in forum CNC Tooling
    Last Post: 05-19-2007, 12:45 AM
  2. 1mm across flats allen key ?
    By greybeard in forum European Club House
    Last Post: 01-19-2007, 10:10 PM
  3. steppers without flats on shafts
    By davidma in forum Stepper Motors / Drives
    Last Post: 12-04-2006, 01:25 AM
  4. Milling Flats
    By ajl6549 in forum Fanuc
    Last Post: 11-03-2006, 07:36 PM
  5. Mill 2 Flats On A Cnc Lathe
    By cncmcguire in forum Vertical Mill, Lathe Project Log
    Last Post: 06-09-2006, 01:15 AM
