586,116 active members*
3,469 visitors online*
    Delta 20 programming error
    I'm having trouble running code with my Delta 20...
    It loads no problem...code is generated by CamBam and it "looks" Dynapath compliant to me...
    No spaces...
    1 G command per line...
    First line N10....
    CR LF end of block commands....
    Numbered lines....
    END at end...
    Looks fine and loads fine then error message at line 10....
    130 improper character....
    The display version on the control has a bunch of spaces added in that aren't in the raw code.... I'm assuming that's the issue...
    I can write a quick test program on the control and it will run great....
    If I load that same code from my laptop it adds spaces and gives an error message....
    Jan 2009
    52
    Re: Delta 20 programming error
    Just a simple note the the CR is carriage return and LF is line feed. These should not be characters that show on the screen but general formating. I think that is your problem. Not familiar with your CAM but in the setup it may ask if you want a CR or LF at the end of every line. Good Luck
  1. E-Stop error Dynapath Delta 10
    By boysandjeep in forum Dynapath
    Last Post: 02-18-2013, 06:41 PM
  2. Delta 20 Checksum Error
    By davidshearer in forum Dynapath
    Last Post: 02-10-2013, 02:39 AM
  3. Replies: 4
    Last Post: 03-07-2012, 05:13 AM
  4. Delta tau nc2.36 servo error
    By JR1050 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-02-2009, 05:59 PM
  5. Dynapath Delta 20 Programming Manual
    By BugEyedValiant in forum Tree
    Last Post: 01-24-2009, 12:57 PM
