586,103 active members*
3,726 visitors online*
    Jan 2016
    25
    Stepper locks up
    I am having a problem where my X stepper motor fails to feed under combined X and Y motion.
    I diagnosed with some 0.33" cuts in cedar. I can easily feed at 20 IPM in either X or Y, but under combined motion as low as 8IPM , the X "locks up", making a humming noise a bit louder than normal operation, it'll stay locked up even if I let off the Y, and will only start back after a release/repress if the x+ button.
    Before I go start playing rubrix cube with my components, anybody have a educated guess at which component it is? It's clearly biased toward the X, but only under combined load, so could it be the PS?
    If it sounds like it's most likely a certain component I'd be happy to just try replacing that component, my tinkering time is going to be pretty limited for the next month or so.
    Steppers: KL23H276-30-8B | Drives: KL-4030 | PS: S-350-36
    Re: Stepper locks up
    What control software?
    Check your CPU usage when it's stalling.
    Jan 2016
    25
    UC100/Mach3, laptop has a high end i7 CPU fwiw
    Also, it appears to be load dependent, doesn't happen if I'm not cutting
    Sounds like a mechanical issue then.
    Quote Originally Posted by averageJoe576 View Post
    I'd start simply swapping the X and Y driver connections ... you need some reference and if the fault stays with the x axis it's more likely to be the motor/mill end. If it swaps to Y then change the input side back and swap the pin assignment ... but I doubt it's the UC100 end.
    Lester Caine - G8HFL
    http://medw.co.uk - Home of electronics for the Model Engineer
  1. V4.33J locks up computer?
    By turbothis in forum Dynomotion/Kflop/Kanalog
    Last Post: 02-21-2015, 01:46 AM
  2. Fun with my X3, Channel locks!
    By binfordw in forum X3/SX3/G0619/G0463
    Last Post: 02-16-2013, 05:13 AM
  3. New VF4 Door Locks
    By Garfish in forum Haas Mills
    Last Post: 04-26-2011, 04:00 PM
  4. Axis locks.
    By BlackMoon in forum Charter Oak Automation Support Forum
    Last Post: 10-30-2009, 07:00 PM
  5. Mach Locks Up
    By pzzamakr1980 in forum Mach Software (ArtSoft software)
    Last Post: 02-25-2008, 03:30 AM
