586,493 active members*
1,749 visitors online*
IndustryArena Forum > CAM Software > Mastercam > G54 and tool offsets to be equal
Results 1 to 6 of 6
    Sep 2005
    71
    when i pull up a tool is there a way so the height and dia. offset follow the tool number offsett or do i have to manually change it.
    how do i keep the g54 as a default so i dont have to manually set it in each toolpath. I keep getting a g92 when i post and not a g54
    Aug 2005
    578
    op manager. properties of that tool path. first page, click on misc values. Misc interger #1 needs to be a "2" to get G54's instead of G92's. Then click Planes and at the bottom of that window is a tic box called Work offset. "0" is G54. "1" is G55 etc.
    That ought to get you what you need.
    Sep 2005
    71
    i know how to change it in the operations manager but i hate having to remember to change it in every one so im wondering if there is a way to keep it at 2 (g54). thanks
    Aug 2005
    578
    change it in edit commopn parameters and save that empty file. The one that MCX2 calls when you start up.
    I think it's in settings and preferances.
    Mar 2006
    1013
    At the bottom of the Misc page is a check box "Use post values" or something like that. Check the box. Most likely your post was set to use mi1 = 2, but when you updated Mastercam didn't set that as the default.
    Mike Mattera
    Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
    http://www.tipsforcadcam.com
    Apr 2003
    3578
    What version of Mastercam? but so you know you want to set this in the defaults so every time you pick a path it is set for you.
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
  1. more tool offsets
    By ALLtra Mach in forum Fanuc
    Last Post: 02-26-2007, 01:45 PM
  2. Tool offsets
    By Clemmie in forum Haas Mills
    Last Post: 12-21-2006, 08:24 PM
  3. Set Tool Offsets in NC Program??
    By alfalfa in forum CamSoft Products
    Last Post: 10-06-2005, 05:47 PM
  4. Tool offsets
    By plateroomred in forum CamSoft Products
    Last Post: 05-28-2005, 08:43 PM
  5. Tool Offsets
    By Hack in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-24-2005, 12:28 AM
