586,060 active members*
4,158 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Anyone using one of those 60,000 rpm spindles on homemade CNC machine?
Results 1 to 11 of 11
    Mar 2017
    926
    I'm curious about these ultra high frequency spindles. You don't see much info on them here. I get that the ones made by Yager, GMN, Weiss and IMT are probably too expensive for your average hobby user but I noticed that cheaper copies from China and Taiwan have started appearing on eBay recently. ATC variants start as low as $1100. Is anyone here planning to buy one?
    I had assumed that they were of little use outside of micro-engraving applications but Datron machines use them for full-on milling applications in aluminum and steel. I wonder if there would be any benefit in using one instead of your typical 24,000 rpm CNC router spindle on a machine for aluminum projects.
    If anyone here has one, is it your main spindle or a 2nd spindle? What sort of project do you use them for? Why did you choose a 40,000 - 100,000 rpm spindle over a 24k one? Do you notice better results in terms of speed or part finish?
    Mar 2017
    926
    Re: Anyone using one of those 60,000 rpm spindles on homemade CNC machine?
    I guess nobody here uses one. Perhaps the affordable ones are still too new.
    35538
    Most people don't have machines capable of properly utilizing a 60,000 rpm spindle, unless you plan on using them for really, small tooling, like 1/16" or smaller.
    Mar 2017
    926
    Please can you explain what you mean by that?
    My understanding is that higher speed spindles with smaller tooling produce less cutting forces. This is why Datron machines (the only brand I know that uses high frequency spindles) can be half the weight of other machining centers while offering twice the work envelope. I would have thought that this would make them ideal for the lightweight benchtop machines people use here.
    I can see that many high speed spindles are limited in tool size but, like other types of spindle, this goes up when you buy more powerful variants. Some of the Datron 60,000 rpm spindles can rough with 20mm face mills while the smallest ones only hold up to 6mm end mills.
    The smaller tooling doesn't seem to limit the overall speed on Datron machines though. That YouTube video where they mill an aluminum quadcopter mold in less than an hour is as fast as I have seen. It got me thinking that I had been too concerned with being able to fit larger end mill sizes and not concerned enough with speed.
    Nov 2012
    1267
    Quote Originally Posted by Goemon View Post
    If you increase your spindle RPM, you would have to increase your feed speed accordingly, otherwise the tool will be rubbing and burning instead of cutting. Lightweight benchtop machines are not usually capable to run at the speed and acceleration required for a 60000RPM spindle.
    The quadcopter mold milling you mentioned was done on a Datron M8Cube. 1.7x1.7x1.9 meters, 1300kg, 22000mm/min feed rate - in other words, nothing like "lightweight" or "benchtop".
    Mar 2017
    926
    Quote Originally Posted by CitizenOfDreams View Post
    I wasn't comparing cheap benchtop machines to the M8cube. I was pointing out that at 1300kg, it is a fraction of the weight of other VMCs and that Datron says this is because their high speed spindles generate a fraction of the cutting forces that typical VMCs generate when cutting aluminum and steel. I'll also point out that Datron puts high speed spindles on all their machines (including the tiny Neo), not just the M8.
    So.... carrying on from that thought.... and again, without comparing a $4000 benchtop machine to a $150,000 Datron.... if a higher speed spindle with smaller tooling reduces cutting forces which enables you to get away with a lighter design, I was asking why more speed wouldn't be beneficial to cheaper benchtop machines (as they are limited by lightweight aluminum gantry beams etc).
    Now... you are suggesting that the primary limitation is that it's not possible or practical to make a lightweight benchtop machine travel fast enough to cut with a 45,000 or 60,000 rpm spindle. But why is that?
    Is it not easier to increase the speed on a 75lb gantry or a 60lb table than it is on machines with a 500lb table? Why can't you just get higher lead ballscrews, larger motors and, if needed, higher gearing ratios until it moves fast enough to cut at 45000 or 60000 rpm?
    35538
    For the same reason you can't put an 800HPmotor in a KIA and end up with a Ferrari.
    You can't just take a machine designed run at 300ipm, and start running it at 1200ipm. Everytime you upgrade a component of a machine, it exposes the next weakest link.
    "Reducing Cutting Forces" is a bit misleading. It reduces cutting forces by taking lighter cuts. You can get the same effect with a 24,000 rpm spindle by lowering the feedrate.
    Since 99% of the users here are not doing high production, they can live with lower feedrates at 1/3 the cost of a high speed machine.
    Mar 2017
    926
    That makes sense.
    It sounds like you are not saying that it isn't possible, just that you have to design a machine to handle it from the ground up. I.e. It's a similar priniciple to why you can't put a 10hp motor on an LMS mini mill. You would need a significantly larger, stronger and stiffer frame etc.
    It also sounds like you are saying that the upgrade is not worth the effort over what you can achieve with a 24,000 rpm spindle.
    What would you say is the main limitation that would need to be addressed before you can double the speed on a machine? Is it about strength and stiffness or is it about the bearings?
    Oct 2007
    30
    We are using 60000 rpm ATC spindle on one of our machines we manufacture.
    Its DATRON like design, featuring 750w servos, 20000 mm/min feedrates. Vacuum table, precise vise and many more...
    See the changer in action here:
    https://youtu.be/AzhZMCEuMDc
    Jun 2011
    692
    For non-production machines, having too slow of a spindle isn't usually a big problem, as it usually just makes things take longer.
    Too little torque on the other hand is a very common issue.
    15362
    That makes sense.
    There are many machines that use these 40,0000 to 60,000 RPM spindles some go to more than 100,000
    Here is one https://www.sodick.com/products/high...igh-speed-mill Most major machining center manufactures that build the top machines in the industry have models with high speed spindle options
    One thing Datron is not doing is running a 20mm face mill at 60,000 RPM and not even at 40,000RPM they have different spindles for there machines, and depends on what there customer needs, most don't go above 40,000RPM if you watch some of there videos you will see the RPM and Feed Rate the use for the different size cutters
    Mactec54
  1. what the 12 spindles cnc router machine doing?
    By Tancy_CNC in forum XYZ Gantry Routers
    Last Post: 08-06-2016, 07:33 AM
  2. Three spindles cnc router machine
    By Tancy-CNC in forum XYZ Gantry Routers
    Last Post: 08-03-2016, 02:29 PM
  3. 3 spindles CNC machine on show
    By Fanny-Roctech in forum Roctech CNC Routers
    Last Post: 03-24-2015, 06:14 AM
  4. Homemade CNC Machine Help
    By chaslam07 in forum DIY CNC Router Table Machines
    Last Post: 04-04-2012, 02:10 AM
  5. homemade machine help
    By cadfish in forum Uncategorised MetalWorking Machines
    Last Post: 03-22-2006, 06:54 AM
