586,357 active members*
3,464 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Machine decided to home x in the opposite direction
    Jul 2006
    130
    Left the machine not estopped overnight, not my normal practice. But I warmed it up in the morning and everythings been going well.
    Experimented with G88 and the machine hung above the part cycling but nothing going on besides that. Halting the program and restarting, trying to run a different one, etc. Nothing worked. The tool changer wouldn't sync up so I couldn't change tools verify tools etc.
    Hit estop to shut down and the entire machine went dark. Giving it a few minutes it booted back up but when I homed it started going in the wrong direction on X. Aborted that, its now powered down. Giving it a breather now while I post this. Opened the back door in case it was a heat issue but I don't feel anything abnormally hot.
    Jul 2006
    130
    Think I got it all sorted
    Jul 2006
    130
    Re: Machine decided to home x in the opposite direction
    Maybe not all sorted, but its homing correctly again.
    Doing any sort of tap op royally screws the machine up though. G84 or G88 and the machine sticks at that line. Estop or halt and tool changing stops working (it will orient but not register it did that and get stuck) Reboot sorts it out.
    I'll post a thread with a good title for this issue.
    Apr 2010
    64
    DOyou think the post you provided isnt good? I was going to give it atry tomorrow and see if rigid tapping works.
  1. Reference All Home - slave motor moves opposite direction
    By jack64 in forum DIY CNC Router Table Machines
    Last Post: 09-22-2017, 11:53 PM
  2. CNC problem, X goes in the opposite direction
    By tilen986 in forum Mach Software (ArtSoft software)
    Last Post: 12-15-2015, 05:30 PM
  3. Replies: 5
    Last Post: 11-13-2015, 06:19 PM
  4. slaved motor runs in opposite direction of master on gantry machine.
    By johnwlindsay in forum Mach Software (ArtSoft software)
    Last Post: 11-15-2014, 11:55 PM
  5. Mach3 is moving in the opposite direction
    By maly-miller in forum Mach Mill
    Last Post: 03-04-2014, 03:00 PM
