586,100 active members*
2,708 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Huanyang VFD speed control
Results 1 to 8 of 8
    May 2018
    28
    Dear All,
    I have just bought a Huanyang VFD and I am wiring it. I have a doubt about how to control the speed, I have checked in many forums, but there are a lot of different theories, so I would like to start a new thread trying to clarify this issue.
    The speed in the VFD can be controlled with an Analogic input (0-5V or 0-10V according to the settings), instead I would prefer to use one of the digital outputs of my UCBB. So I would like to understand if the VFD has already a RC built in circuit so I can directly wiring my PWM output to the Analogic input of the VFD.
    15362
    Re: Huanyang VFD speed control
    Quote Originally Posted by morfeus80 View Post
    Dear All,
    Yes the normal way to connect the 0-10v or 0-5v PWM direct to the VFD for the speed control the connection is VI and ACM for speed control
    For On / Off relay switched FWD and DCM connection, this is just a switch connection
    There are some Parameters and a Jumper that need to be set as well
    Mactec54
    No, you can't control it that way.
    24221
    You need a PWM to Analogue convertor of some kind.
    What BOB or interface are you using, if any?
    There is also a Mach3 plug-in for the RS485 serial.
    Edit
    Al.
    Albert E.
    There's a plugin for UCCNC as well that uses RS-485.
    May 2018
    28
    Said that I would prefer to use the RC filter instead that the plugin, I have read a lot of documentation and examples and it looks like that the VFD has some sort of filter, so using the PWM at high frequency it should be fine. I think this filter can be set using the parameter PD071 of the VFD, did anybody try?
    24221
    I see PD071 as the response time of the Analogue in, But try it and see what happens! .
    Al.
    Albert E.
    15362
    PD071 Analog Filtering Constant
    The setting of this parameter is related to the analog responding speed. The higher the value of PD071 is set, the lower the analog responding speed will be.
    Mactec54
  1. MX4660 Speed Control for 2.2 KW huanyang vfd
    By Dekman in forum Leadshine
    Last Post: 06-27-2022, 10:10 PM
  2. Huanyang Inverter How to set and wire spindle at speed
    By TTalma in forum Spindles / VFD
    Last Post: 12-20-2018, 07:25 PM
  3. Replies: 11
    Last Post: 04-13-2018, 12:52 PM
  4. HUANYANG VFD ADJUST SPEED
    By instructor37 in forum Spindles / VFD
    Last Post: 02-14-2015, 12:28 AM
  5. down arrow and speed decrease huanyang vfd
    By curiosity22 in forum Phase Converters
    Last Post: 04-19-2014, 02:20 AM
