586,082 active members*
3,534 visitors online*
IndustryArena Forum > Community Club House > International / Regional Forums > Australia, New Zealand Club House > Flow control valves in Australia for 1 shot oiler? And other fittings?
    Mar 2017
    98
    Hi all anyone know a supplier in Australia for small oil control valves and other stuff like manifolds that would suit a 1 shot oiler project? Looking to make one for my cnc benchtop machine (conversion).
    Similar to the stuff in this pic:
    Jun 2010
    4256
    Re: Flow control valves in Australia for 1 shot oiler? And other fittings?
    Many control valves are meant for compressed air, not oil. Some of them have neoprene rubber parts, and neoprene can absorb oils and swell up. So some caution is needed. Nitrile and Viton rubbers are good.
    Also, a lot of compressed air fittings are not especially good at sealing at the couplings. Any air leakage doesn't matter, but slight oil leaks can make a horrible mess. I resorted to teflon tape.
    I have been using AirTac solenoid valves (via eBay) on my MQL system and so far they seem to be OK.
    Cheers
    Roger
    Sep 2018
    35
    Did you end up finding a supplier for these parts?...mine leeks all over the place as well..and I cant bleed the system because of it...I have resorted to oiling myself with a brush till I can sort the issue with the leaking joints.
    Jun 2010
    4256
    Leaking joints ====> Teflon plumbers tape
    Cheers
    Roger
  1. ONE SHOT OILER MODIFICATION
    By JTJT in forum Shopmaster/Shoptask
    Last Post: 04-03-2017, 02:58 PM
  2. Preferred oil in one shot oiler?
    By bit pusher in forum Charter Oak Automation Support Forum
    Last Post: 10-31-2013, 06:22 PM
  3. One shot oiler question
    By g29cc in forum Novakon
    Last Post: 09-09-2010, 04:09 PM
  4. One shot oiler
    By Bubba in forum Uncategorised MetalWorking Machines
    Last Post: 12-01-2009, 03:39 AM
  5. metering valves for one shot oilers?
    By thomasfreedy in forum Benchtop Machines
    Last Post: 03-31-2009, 05:35 PM
