586,070 active members*
3,543 visitors online*
IndustryArena Forum > CAM Software > CamBam > cambam with Syntec 6mb controler
    Jan 2019
    Hello, I'm French excuse my approximate English
    I have a chninese cnc omnitech 2040 with tool changer and I use cambam, is there a post processor for syntec 6mb ?? because I can not operate the tool change in the gcode, or I have a problem in the machine.
    I explain to you when I create toolpaths with change , the machine does not compensate my different heights from a tool to the other.
    Do you have an idea of the problem or have you already met
    Thank you
    Sep 2012
    228
    Re: cambam with Syntec 6mb controler
    Hello,
    your post processor has to insert a tool length compensation command.. with a reference to the tool table.. so it knows how much to compensate.
