586,094 active members*
3,972 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Please rank the rigidity of these linear bearing options
Page 2 of 2 12
Results 21 to 32 of 32
  1. #21
    Mar 2011
    357
    Re: Please rank the rigidity of these linear bearing options
    Quote Originally Posted by nlancaster View Post
    And if you want Hiwins, automation4less.com has from what I can see pretty good prices on them.
    Well that is almost twice the price of automation overstock so I can't afford that but thanks.
  2. #22
    Mar 2011
    357
    2) Having someone here in the states that stands behind their products is worth something. If you have problems, it's worth a lot.
    3) I still spent $1500. They were more expensive than the Chinese versions they sell now.
    Well I spent some time on the phone with Kent from Automation Overstock and I have to say he is a wealth of knowledge and a real talker.
    Super nice and informative guy.
  3. #23
    35538
    Never spoken with him, but have exchanged email several times. Excellent service when I had a minor issue with an order.
  4. #24
    Jul 2009
    85
    I guess i dont understand with the price of profile rails and ballscrews so low why people keep messing around with other options...
    Sent from my LM-Q710(FGN) using Tapatalk
  5. #25
    May 2005
    3920
    Quote Originally Posted by minichopper6hp View Post
    It is the difference between a business expense and a hobby expense. I know personally the funds simply are not there for an extravagant build so I've held off because I know I would not be happy with a flimsy machine. However I'm not an absolutist with respect to bearing selection, a lot of round rail problems would diminish if large sizes where selected. Of course that ups expense and pushes one towards profile rails. Round rails are often associated with unsupported rail systems which is clearly a bad idea on long spans.
    I have to agree though that sometimes the decisions people make end up not making sense to me. Saving money by buying round rails and then making the entire machine frame out of extruded aluminum for example does seem like putting money into the wrong area. So yea the cash allocations on some builds don't make sense to me but those are not my machines nor my pocketbook.
    The other positive for round rials is their freedom to rotate a bit on the linear rails. This can be a positive on wood framed machines that might not be perfectly flat with respect to to the rail mounting surfaces. Sometimes the project simply doesn't permit building good enough to justify profile rails.
  6. #26
    Jan 2013
    76
    One option that hasn't been mentioned is Alu extrusion with the insert that holds round rods. The bearings that ride on these rods are substantial. In my comparisons between the supported round rails with the flimsy wagons and the Item brand round rails and bearings they are miles apart in quality. But they are not inexpensive either. I like them for the ease of use.
  7. #27
    Mar 2011
    357
    Quote Originally Posted by Black Forest View Post
    that is a new one
    Where do you get that stuff?
  8. #28
    35538
  9. #29
    Mar 2011
    357
    Hey Ger21, your PM box is full.
  10. #30
    35538
    Try again.
  11. #31
    Mar 2011
    357
    Ya I saw those but have never seen anyone on these boards using them for CNC.
  12. #32
    May 2005
    3920
    There are actually a number of linear motion solutions out there that don't exactly fit into the profile rail category nor the round rail category. At work we have a large number of plastic injection molding machines that have various extractors attached. Some manufactures use the same old profile rails we see here while others have systems somewhat like you posted here. One could spend hours reviewing all the solutions out there, some have more potential than others in a router type machine.
Page 2 of 2 12
  1. Replies: 4
    Last Post: 06-15-2015, 01:20 PM
  2. Bearing options/design for small z-axis?
    By cnczoner in forum Linear and Rotary Motion
    Last Post: 07-14-2011, 05:11 AM
  3. Linear bearing options
    By Grogyan in forum 3D Printer / 3D Scanner Discussion
    Last Post: 04-06-2011, 12:56 PM
  4. Cost-Cutting Custom Bearing Options from PBC Linear
    By Pacific Bearing in forum News Announcements
    Last Post: 05-28-2010, 06:23 PM
  5. Linear bearing spacing & Sizing linear rails?
    By fyffe555 in forum DIY CNC Router Table Machines
    Last Post: 12-07-2004, 08:09 PM
