586,036 active members*
3,612 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > AL-12 spindle servo alarm Fanuc OM shuts down when it comes to clearance /M5/M9
    Jun 2006
    170
    I have an older fanuc controlled machine and for the last little while we have been having an intermittent issue. Someti.es when a tool is finished its program and it comes to clearance the machine shuts down and enters "not ready" state. When i say intermittent i mean 5 to 10 times a day but not every time.
    When it shuts down the digital display on the spindle drive gives an alarm. I cant remember the number as i am home now but i looked it up and it was something to do with a voltage variance or drop.
    I am guessing a broken wire but we are trying to finish a job and i am scared to stop and start looking until we nurse it through the job.
    Right now i am trying to do a bit of research to see if there is any other area i may look. We did the once over checking wire connections and some simple stuff. I hate intermittent problems. Can be so hard to sort out sometimes. I will look up the alarm number and post that in the morning.
    Jun 2006
    170
    Quote Originally Posted by kirby View Post
    Now the machine is down and i cant get it back.not sure if it is relevant or not but in the diagnostic parameters page parameter 0054 has the 4 numbers on the left flashing between 0 and 1 as well as parameter 0058 has the 4 on the right flashing as well.
  1. Fanuc Alarms and then machines shuts down
    By flandaeta in forum Fanuc
    Last Post: 11-25-2016, 06:37 PM
  2. Fanuc 6m shuts down
    By gusf in forum Fanuc
    Last Post: 10-13-2016, 06:16 AM
  3. Fanuc 3T NC shuts down randomly...
    By amercc in forum Fanuc
    Last Post: 08-26-2013, 02:29 PM
  4. fanuc 6t shuts down by itself
    By liltommy63 in forum Fanuc
    Last Post: 02-25-2013, 11:37 PM
  5. Fanuc 10T E Stop Shuts off Control
    By charger19690 in forum Fanuc
    Last Post: 06-15-2011, 02:56 AM
