586,105 active members*
3,297 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Taig Mills / Lathes > YouTube Videos of Taig Mill controlled via USB and SuperCamXp
    Taig Mill Draw and Cut with SuperCamXp, 06:47 minutes
    http://www.youtube.com/watch?v=L1-mF14GYhU
    Engraving Shamrock from DXF file on Desktop Taig Mill, 06:18 minutes
    http://www.youtube.com/watch?v=ORC4qnpk2ls
    DXF to G-code File SuperCamXp Tutorial, 02:38 minutes
    http://www.youtube.com/watch?v=VGDbULSvTEA
    You might find the videos entertaining. They demonstrate my approach to machine tool control.
    The Taig Mill has stepper motors, that are micro stepped at 1600 steps per revolution. This gives a step size of 0.00003125 inch for each axis.
    The Mighty Box controller has the USB interface built into it. There are also two relays built in, the relay A is used to turn on/off the spindle motor. The Relay B can be used to automatically turn on/off cutting fluids.
    The control software is SuperCamXp, which is a direct CAD interface to the mill. The mill follows the centerline of the graphic items in the drawing. Tool path drawings can be created within the program or imported from other CAD applications.
    There is usually no need to use G and M code files. The drawing is the tool path. There are drawing editing commands within SuperCamXp.
    The graphics area is animated with the mill’s movement in real time. The space bar acts as the emergency stop when the machine is in motion.
    There are more videos on how to use SuperCamXp at my web site at:
    http://www.super-tech.com/root/itm.a...amxp-tutorials
    SuperCamXp also works with my USB CamPod, that has a parallel port connector on it. This way I can use it with the Gecko Powered controllers, I make with the more common step and direction parallel port interface.
    Dennis Bohlke
    Now that is a cool system.
    Wish I could afford it.
    Hoss
  1. Replies: 13
    Last Post: 11-04-2011, 02:46 PM
  2. Coming Down to the Taig Micro Mill or Grizzly Mini Mill.
    By CROSSHATCH in forum Taig Mills / Lathes
    Last Post: 01-23-2009, 06:14 AM
  3. cnc controlled mandrel bender controlled by mach3
    By timmyb199 in forum Bending, Forging, Extrusion...
    Last Post: 05-31-2007, 12:35 AM
  4. CNC Taig mill
    By WOODKNACK in forum Taig Mills / Lathes
    Last Post: 06-17-2003, 04:13 AM
