586,121 active members*
3,243 visitors online*
IndustryArena Forum > CAM Software > SolidCAM for SolidWorks and SolidCAM for Inventor > SAME .GPP DIFFERENT CODE GENERATED - I NEED HELP
Results 1 to 1 of 1
Threaded View
    Oct 2007
    38
    Hi! I have adapted, over the years, an old postprocessor for my really old DECKEL FP4MA. The post processor works just fine but now with the new SolidCam 2017 we got some problems. For example one thing that I cannot understand is why if I open a .prz done with previous SolidCam 2012 into SolidCam 2017 it generates the code correctly but if I did the same piece, same functions, all equal the 2017 version generates something different. I repeat, the .GPP is still the same...
    Basically the main different is that the right code uses @line and @arc function besides SolidCam 2017 uses only @line function which cause that the cede generated passes the line limit imposed from the DECKEL memory.
    I've attached all the files needed. Maybe someone could help me solving this issue... thanks.
    Attached Files Attached Files
  1. No g-code file generated by Madcam in Rhino
    By Viesturs in forum MadCAM
    Last Post: 11-07-2018, 07:02 PM
  2. G code generated for plasma cutter
    By mohamedmetwally in forum BobCad-Cam
    Last Post: 03-18-2015, 11:08 PM
  3. Error 021 Fanuc with generated NC code from Edgecam
    By rookiemistake in forum Fanuc
    Last Post: 03-06-2015, 12:21 AM
  4. Replies: 8
    Last Post: 12-15-2010, 09:32 PM
  5. HDI remove the .5 x,y offset generated in Mach 3 when I upload code?
    By billmiller in forum Mach Software (ArtSoft software)
    Last Post: 08-20-2010, 01:33 AM
