586,036 active members*
4,277 visitors online*
IndustryArena Forum > Tools / Tooling Technology > CNC Tooling > Making a 4.25" cut 2.5" deep
    Hi guys I have to make this trim piece out of aluminum 4'x6' rect. bar
    im pretty much turning it into an H with the cut being 4.25 wide and 2.5 deep
    what type of tool would you suggest im thinking maybe like a face mill or fly cutter ... but the fly would have to be designed where the cutting edge was at the furthest point so as not to hit the wall of my part.
    I attached a pdf if that helps. and thank you for any advice you can give.
    jeremy
    Dec 2013
    5717
    Re: Making a 4.25" cut 2.5" deep
    I assume you mean 4x6 inch aluminum bar as opposed to 4x6 foot. (4'x6')
    What machine are you going to use to do this?
    An insert type endmill might be the best.
    Jim Dawson
    Sandy, Oregon, USA
    yes sorry i did mean 4"x6"
    I am running it on a kia va 50 max spindle speed is 2500 rpm
    Dec 2013
    5717
    With a 2500 RPM spindle this is going to take a while to run. But given your machine, I think about a 2.5 inch carbide insert end/face mill and a trochoidal cutting pattern would make the most sense. Follow the cutter manufacturer recommendations for feed, speed, & DOC. You will have to adjust feed down to keep the correct chip load at your RPM.
    Jim Dawson
    Sandy, Oregon, USA
    thank you
  1. Drill .059" hole 1.200" deep on Stainless Steel 316L
    By liusvet in forum CNC Swiss Screw Machines
    Last Post: 01-25-2017, 06:35 PM
  2. Cut "deep" corners for a pocket? Square peg into a round hole!
    By Borisw37 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 08-08-2016, 07:10 PM
  3. How to "Drill" a 1/2-20 thread hole 1" deep on a Tormach in Ti-6Al4V
    By ChrisPhoenix in forum Material Machining Solutions
    Last Post: 07-18-2015, 01:05 AM
  4. Replies: 23
    Last Post: 01-23-2015, 11:57 PM
  5. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
