586,042 active members*
3,753 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > HTD5M Belt flexibility Urathane or Rubber?
    Nov 2018
    53
    Hi Gang!
    I just got in 5 meters of white 30mm wide HTD5M belt. This has steel reinforcement.
    I find it kind of stiff. I hope is can go around the pulieys okay. I need to order 15mm belt, today. I see black belt called "rubber" also some referred to as "Neoprene".
    What are your thoughts on the White Urethane belt vs, black "rubber?"
    Is the stiffness a problem? I'm guessing mostly the steel wire is creating the stiffness.
    thanks
    Dec 2013
    5717
    Re: HTD5M Belt flexibility Urathane or Rubber?
    The belt will go around a 3 inch or so pulley just fine. The other option is to get a belt with Kevlar reinforcement, it's a bit more flexible the the steel.
    The neoprene should work fine also. I have normally used the white urethane belts for long runs (up to 7 meters or so) where a lot of tension is required and moving loads of several hundred lbs.
    Jim Dawson
    Sandy, Oregon, USA
    Nov 2018
    53
    Jim!
    I'm going to have to send you a Birthday Present:-)
    Your knowledge is amazing. And I really appreciate getting your opinion before I make a purchase. The white 30mm wide belt I have is plenty strong. I just though it may be too stiff, but you are right, over 1500mm to 2000mm it should be fine.!
    Dec 2013
    5717
    Thank you for the kind words. I have been building machines for various applications for about 50 years, so have a little experience with what it out there to work with.
    Jim Dawson
    Sandy, Oregon, USA
  1. RFQ HDU Urathane carving 4x8 or 6 x12
    By PJP_REST in forum RFQ (Request for Quote)
    Last Post: 01-18-2012, 05:55 PM
  2. Which CNC Control offers the most Flexibility
    By Joner101 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-12-2010, 01:20 PM
  3. what design for a DIY cnc offers most flexibility to change and add on to
    By gandolf123 in forum DIY CNC Router Table Machines
    Last Post: 01-26-2010, 06:17 AM
  4. Sponge Rubber and Diamond plate looking rubber?
    By DennisCNC in forum Community Club House
    Last Post: 06-01-2007, 06:15 PM
