586,457 active members*
3,337 visitors online*
Results 1 to 8 of 8
    May 2018
    28
    Driver settings
    Dear all,
    I have a DM542T driver and I am not sure about the settings to choose.
    In the settings of microstepping is not explained how to set it with full step. I think to do it I have to put all the switches in ON position... do you confirm it?
    Furthermore I am using a Nema23 that is rated at 2.8 Amps. I don't know if I have to set the driver for 2.8 Amps of peak current or of RMS current?
    Jan 2016
    10
    Re: Driver settings
    I just completed a small plasma table with the same component selection as yours. Page 7 in the manual linked below should answer your questions.
    https://www.omc-stepperonline.com/download/DM542T.pdf
    Sent from my iPad using Tapatalk
    May 2018
    28
    Re: Driver settings
    I had already read the manual, but both my questions are not solved there...
    35538
    Re: Driver settings
    The most commonly used microstep settings are 1/8 or 1/10.
    Use the peak current.
    Jun 2011
    692
    Re: Driver settings
    Looks like the driver can't/shouldn't be used in full-step mode according to the settings table. Any reason you want to use full stepping?
    May 2018
    28
    Re: Driver settings
    I would prefer full step because it allow faster rotation and also more torque.
    Jun 2011
    692
    Re: Driver settings
    Only allows faster rotation if you're pulse-rate limited. Not likely at half-step. Shouldn't lose any torque either. You may need to experiment with current values (don't exceed the stepper rating in the RMS setting,) but you should be able to get as much torque with half/micro stepping as with full-stepping. You will need to keep the reduced idle current mode enabled.
    May 2018
    28
    Re: Driver settings
    I have done a test: I have put all the switches relative to the microstepping seeing in ON position, that is the only combination not present I the manual and like that the controller moves the mirror at full step... I don't think this should create any issue...
  1. Why are there two half step settings on my driver? A or B?
    By devo9er in forum Stepper Motors / Drives
    Last Post: 06-15-2016, 12:34 AM
  2. how to set decay settings on tb6560 cnc driver
    By grahamshere in forum Stepper Motors / Drives
    Last Post: 08-14-2014, 09:18 PM
  3. Stepper driver settings 1/8 vs 1/2
    By BubbaGump in forum Australia, New Zealand Club House
    Last Post: 11-17-2009, 11:46 PM
  4. 4030 Kellinger driver settings
    By Paul R in forum Automation Technology Products
    Last Post: 09-10-2008, 06:37 PM
  5. Need a little help with Current settings on driver...
    By giblets in forum Stepper Motors / Drives
    Last Post: 08-24-2006, 03:19 AM
