586,075 active members*
4,033 visitors online*
IndustryArena Forum > Hobby Projects > Hobby Discussion > First CNC Mill Design - General Questions
Results 1 to 3 of 3
    Hi all,
    I've been toying with the idea of building a CNC Mill. And with that, I must start with design! I've been lurking around the net on CNC Hobby projects and forums. Before I can model my design, I have some general questions about equipment that i think if answered would save me a lot of hassle and time.. perhaps even money.
    Some basic info of what I am envisioning
    Goal: 3 axis Steel and Aluminum milling machine. Repeatability the best I can get. Would be very happy with +/- .0012"
    Budget: Undecided entirely. If I can reach good repeatability and power, a few thousand USD.
    Work Envelope: 20" x 12" x 8" (X,Y,Z)
    Motors: NEMA 34
    MOTION CONTROL: Ebay ball screws, ebay HSR Linear Rails, 2 per axis, Z-Axis considering going with rod style ways to save money.
    Spindle: Was looking at ebay spindles for a few hundred.
    [B]Frame:/B] Custom machined steel frame design (bolt and assemble type design)
    Table / Mounts: I may go with Aluminum for the table as a substrate and bolt a thinner (5/16") steel top to it for lessesning load on the X and Y axis motors. Aluminum mounts for different pieces where acceptable.
    Control Gecko drive, not worried about electronics at the current time
    With that said, here are my questions for the experts:
    1.) With the HSR linear rails, I found that pricing for larger HSR rails gets pretty steep the wider you go. HSR25 has a major rail width of 23mm. Do you believe this is rigid enough (2), or would stepping up to a HSR 30/35 be worth the 50-100% increase in price?
    2.) Assuming ebay parts and the best rigid design possible with this hardware, do you believe my repeatability is realistic with amazon/ebay ballscrews?
    3.) What is the proper term for finding "accordion" chip guarding. I don't know how to word that. I am referring to the chip covers that stretch and contract with the table to cover the ways and screws.
    Any other comments/tips on my design are welcomed. Thanks for reading.
    Regards
    Dec 2013
    5717
    Re: First CNC Mill Design - General Questions
    If I understand correctly, you want to use this machine for milling steel and aluminum, and you have a budget of a few thousand USD.
    Just buy a used milling machine. Preferably a CNC, that way the hard work is already done. Then upgrade as needed. No point in reinventing the wheel.
    For instance, I paid $1000 for my 32x12.5x12 (10x52 table) CNC machine that was in nearly perfect mechanical condition. I did a controls upgrade later. A friend of mine picked up a similar, but heavier and with a tool changer, machine for $2500, and we did an upgrade on it also.
    Jim Dawson
    Sandy, Oregon, USA
    Apr 2014
    432
    From what I have seen over a few years it's the best advise buy a great used machine , building something is a lot harder than some think.
  1. Bed Mill Design And Fabrication Questions.
    By Overtorque in forum Mechanical Calculations/Engineering Design
    Last Post: 06-20-2018, 12:21 PM
  2. Replies: 2
    Last Post: 05-24-2016, 07:29 PM
  3. CNC mill questions - thrust bearings, leadscrew mounting, general questions
    By tonofsteel in forum DIY CNC Router Table Machines
    Last Post: 02-03-2012, 10:42 PM
  4. General software and controller function and design questions.
    By nworroll in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-06-2011, 08:26 PM
  5. Router Mill Design Questions
    By dfro in forum Mechanical Calculations/Engineering Design
    Last Post: 08-02-2005, 02:01 PM
