586,060 active members*
3,526 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Hardware > Laserpro Explorer II - Error Code 000 IVT: 30000000
    Jan 2019
    Hello all,
    I am getting the Error Code 000 IVT: 30000000 everytime I turn my Explorer II on now.
    I was doing some cutting one day and left machine on at night and it went into standby mode.
    The next day I came out to cut and pushed button to wake it up and it was locked up.
    I powered the machine down and turned back on and now get this code.
    I have pulled the power and let it sit but still same error. I cant really find any info on the code and needing some help to move in the right direction to fix it.
    Thanks in advance
    Shane
    Exclamation Re: Laserpro Explorer II - Error Code 000 IVT: 30000000
    Quote Originally Posted by shanephoward View Post
    Hello all,
    Thanks in advance
    Shane
    Hi Shane,
    I'm having this problem right now! Did you ever find an answer?
    Michelle
    Quote Originally Posted by MICHELLEKOLLAR View Post
    Hi Shane,
    Michelle
    Has anyone ever figured this out? I am totally brand new and just fired up a used machine. It was working when I purchased it and then we loaded it and took it back to our shop. It has set there for about 2 years before we finally got the electric in and ready to roll
    Jul 2008
    I got my hands on a secondhand laserpro spirit - same family and control type as the explorer.
    On startup, it also gave the IVT:300000000 message and keep resetting over and over.
    thanks to https://www.engraversjournal.com/legacyarticles/2564/, it turned out to be the X limit switch
    on figure 12 of the article it is shown as a yellow tab, on my machine it is a black metal tab fixed by a hex screw.
    This screw was loose causing the tab to droop slightly downwards.
    Just enough that the limit switch test fails, causing a system panic/reset.
    refixing the tab correctly solved the issue and allow a complete startup.
    the IVT message was not important nor a error, just a cryptic hello from the machine
    Information on the system is sparse and dated
    hth
