586,116 active members*
3,460 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Puma 8S Y03 Amp Unequipped Spindle Stop Signal
Results 1 to 8 of 8
    Oct 2014
    20
    Just bought a 1997 Daewoo Puma 8S. Have run 2 jobs on it so far. Just booted it up Monday morning and have the error in the title. I've identified that the middle amp in the top of the cabinet is not lit up.
    This happened on Friday, and I turned the machine off, disconnected and reconnected all the DSUB cables going between amps. Turned the machine back on, and it started working and ran all day. Today, this is not working.
    I've ordered a couple replacement cables, but am concerned this is not the problem since I can't get it to work today. If it's an intermittent cable I'd think I'd be able to get it going. Am I barking up the wrong tree? What else can I check while I wait?
    The left AMP says "b" on the back while the right amp is flashing between "F1" and "E7". Can't find anything telling me what these mean.
    Feb 2013
    788
    Re: Puma 8S Y03 Amp Unequipped Spindle Stop Signal
    What is the serial number?
    What is the control model?
    What is the Amp Model or Part number?
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
    Oct 2014
    20
    Serial PM8S 0782
    Control is Meldas 500 NC Type FCA520LR
    Spindle Drive Unit MDS-B-SP-260
    Feb 2013
    788
    Crap!
    Everything I have to assist with servo drives is Fanuc oriented!
    I have not acquired information on the Mitsubishi drives.
    Sorry.
    Oct 2014
    20
    Darn, thanks for trying.
    Quote Originally Posted by dhardt View Post
    Crap!
    Sorry.
    Oct 2014
    20
    I did get the machine running today, but no idea how. I just kept trying to turn it on occasionally. Once on, it runs great. I left it on tonight in hopes I don't have this problem tomorrow, but I don't want to leave it on 24/7.
    Anyone know if this sounds like how a bad spindle drive would behave?
    Mar 2009
    109
    The amp that intermittently lights up is failing. You will need to replace it.
    Oct 2014
    20
    That's what I was afraid of. Thank you for the confirmation.
  1. Replies: 4
    Last Post: 03-10-2018, 07:37 PM
  2. How to add Leadshine alarm signal to e-stop chain?
    By mkuivamaki in forum Servo Motors / Drives
    Last Post: 05-14-2017, 02:50 PM
  3. Replies: 10
    Last Post: 12-21-2013, 09:11 PM
  4. Using the Err/Res signal to e-stop Mach3?
    By fatal-exception in forum Gecko Drives
    Last Post: 08-05-2010, 10:29 PM
  5. Replies: 2
    Last Post: 02-19-2010, 09:28 PM
