586,905 active members*
3,167 visitors online*
Thread: Jog Shuttle
Results 1 to 6 of 6
    Apr 2011
    Jog Shuttle
    Can contour's shuttleXpress be programed to work in place of Tormach's jog shuttle
    Jan 2007
    311
    Re: Jog Shuttle
    It's exactly the same AFAIK, tormach just has their name stenciled on it.
    I use one (the express) on my lathe as well as the shuttle on the mill. Have also used the shuttle pro on hte mill but found it awkward with too many buttons
    M
    Apr 2013
    1788
    Re: Jog Shuttle
    I am using https://www.amazon.com/gp/product/B0032Y0OH0 and it works perfectly.
    Jun 2014
    1780
    Re: Jog Shuttle
    I bought an aftermarket shuttle express, its still in the box, the original is still working after almost 7 years.
    mike sr
    Nov 2012
    591
    Re: Jog Shuttle
    On this topic, I've looked at the ShuttleXpress, and used it in the past, but I don't like it.
    I could use a pendant that had functions for:
    - separate traverse for X, Y, and Z, ideally small wheels but sticks are OK -- the modal single dial is terrible
    - stop
    - run
    - feedhold
    - step/rapid mode switch
    - step size toggle
    - zero for x/y/z
    No more buttons than that! And fewer (start removing buttons from the bottom) would be OK.
    Is there a pendant like this? (Obviously, plug-and-play with PathPilot without having to patch it every update would be vastly preferrable.)
    Apr 2013
    1788
    Re: Jog Shuttle
    I am not aware of anything although there are several pendants that require patches.
    I have split the functions for my purposes: The stop/run/feedhold are provided with a box that emulates a keyboard so no patches are required. I wrote an article giving full details in the Spring 2018 issue of Digital Machinist Magazine.
    I put my jog shuttle in a sealed housing so I no longer worry about it jamming with chips. I don't find the single rotary dial a problem. I just wish that it had buttons to zero the axis!
  1. Shuttle pro macros
    By air2gnd in forum Mach Wizards, Macros, & Addons
    Last Post: 04-12-2012, 12:20 PM
  2. Jog shuttle quirk
    By Tinkertect in forum Tormach Personal CNC Mill
    Last Post: 01-27-2011, 07:08 AM
  3. VF0 toolchange Shuttle
    By lapokerplayer in forum Haas Mills
    Last Post: 08-25-2009, 02:32 PM
  4. Shuttle Pro Plugin mod!!!
    By PoppaBear10 in forum Tormach Personal CNC Mill
    Last Post: 07-28-2009, 03:13 PM
  5. Shuttle Pro and Mach R3.042.020
    By dsage in forum Mach Software (ArtSoft software)
    Last Post: 11-24-2008, 11:27 PM
