586,108 active members*
3,149 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Using same control box for different sized nema motors
    Oct 2017
    10
    Would a control box with Gecko drivers running nema 23 motors be suited to also run nema 14 or 17 motors without needing to calibrate when switching machines?
    I am thinking of adding cnc function to a taig lathe but using the same setup as the taig mill.
    I'm guessing I would have to match the coil resistance. But is there more to this?
    Thank you!
    Peter
    Re: Using same control box for different sized nema motors
    You need to set the current rating on the drives to match the motors.
    Mar 2007
    2083
    Hi Peter
    which Gecko driver do you intend to use ?
    photos of your existing control box connector & the drivers inside will help
    if you have a G540 or individual G251 drivers for example the current is set by a resistor
    (1000 ohms per amp upto the 3.5A limit)
    by fitting the resistor is in the connector on the motor cable
    the current will be correct for which ever machine is connected
    John
    PS
    have a look at this adaptor to connect a 6 wire Taig motor to a 4 wire G540 driver
    Gecko G540 to Taig CNC Mill Motor lead adapters
    note
    the .homanndesigns adaptor shown has a variable resistor on the GC-02 breakout board instead of a fixed resistor
    PPS
    G540 motor connector and current set resistor
Name:	G540 motor connector and current set resistor.jpg
    Oct 2017
    10
    Hi Gerry and John, thanks for your answers.
    I am using the G210. The box has an adjust potentiometer on it and also an external current set resistor. I'm guessing the resistor is the limiter and the adjust pot is the fine tuning.
    So I could open the adjust pot fully and install resistors in the cable to get the same effect but be machine independent. Is that correct?
    Peter
    Mar 2007
    2083
    Hi Peter
    the G210 manual should help
    PDF manual
    Attachment 410090
    Attachment 410092
    Attachment 410094
    I would expect the potentiometer is more likely to be connected to the splidle speed control
    to set the motor current you just need to use the correct resistor value givenin the manual
    John
  1. XHC Mach3 4-axis control card with M542t drivers and Nema 24 stepper motors
    By usajet in forum CNC Machine Related Electronics
    Last Post: 12-04-2016, 03:02 AM
  2. Replies: 0
    Last Post: 12-04-2016, 03:00 AM
  3. Replies: 0
    Last Post: 12-04-2016, 02:51 AM
  4. Will 2 nema 17 motors(42Ncm Each) be used as one nema 23
    By Haitem56 in forum Stepper Motors / Drives
    Last Post: 08-19-2016, 04:19 PM
  5. Replies: 0
    Last Post: 12-17-2013, 01:14 AM
