586,119 active members*
3,397 visitors online*
Results 1 to 12 of 12
    Jul 2005
    7
    spindle and VFD
    Hello. I have been searching for a simple answer and my search skills must need work.
    I bought this spindle and VFD
    https://www.automationtechnologiesin...ooled-spindle/
    I set it up and it seems to function correctly. It spools up to 24000 rpms just fine.
    The VFD only allows 7amp as the max amp draw. Isn't that only 770 watts? I set mine to 5A because that is what I saw online. The vendor told me to set it to 11A, but the VFD won't allow that value.
    I haven't cut anything yet because my CNC has a couple of other issues. I figured I would upgrade to a real spindle while the machine was down.
    The spindle itself has no amperage rating stamped on it. I have seen other 110v 1.5Kw spindles online with 5A stamped on them. It does not seem right.
    I am a hobbyist so there is probably a gap in my knowledge here.
    Any help I can get would be appreciated.
    Dec 2013
    5717
    Re: spindle and VFD
    I'm pretty sure that VFD has a voltage doubler circuit in it, so outputs 220V 3 phase. 7 amps at 220V = about 1500 watts
    Jim Dawson
    Sandy, Oregon, USA
    Jul 2005
    7
    Re: spindle and VFD
    Thank you for the response. Right now it is set for 5A max. I have one of those killawatt devices and it is measuring just shy of 5 amps draw when the spindle is spooling up. If the VFD is pulling 5 amps at 110V from the wall that is 550 Watts. How can it possibly output 1500 watts to the spindle?
    What electrical property am I missing? Like I said, I am a hobbyist. I just want to understand what I am dealing with.
    ericks Guest
    Re: spindle and VFD
    Sorry...for some reason my post from another topic ended up here
    Re: spindle and VFD
    What voltage is printed on the spindle?
    Is there a motor voltage setting in the VFD?
    Jul 2005
    7
    Re: spindle and VFD
    Yeah. It says 110V right on the spindle. I set the VFD voltage to 110. I had to adjust some of their other settings because they were wrong. I knew this thing wasn't drawing enough power. I am going to try to return it. I thought I could get by without running 220v in my basement. I guess I was wrong. That VFD says 110V 1500 watt right on it, but it only lets me select up to 7 amp max draw. That is why I posted here.
    Thank you for the information. I appreciate your help.
    Jul 2005
    7
    Re: spindle and VFD
    I talked with Automation Technology. They are going to take back the spindle and VFD and refund me. I bought the stuff from them because I bought 2 60 watt lasers from them. One in 2014 and one in 2016. Both lasers work great and those guys were easy to deal with. They have always answered my questions over the last few years I have dealt with them.
    I will box the stuff up and ship it back tomorrow. For the sake of completeness I will post how the refund process worked out.
    I am not sure if I will buy a 220V spindle and VFD or buy another router. The Porter Cable router I used worked fine for a long time.
    15362
    Re: spindle and VFD
    Quote Originally Posted by kj0277 View Post
    You can get 120v to 220v VFD Drives and then use a 220v spindle but don't go over 1.5Kw for the spindle size, the 120v supply would have to be quite robust this would need a supply of 25A for the VFD Drive input supply
    Mactec54
    Jul 2005
    7
    Re: spindle and VFD
    Thank you again. If I decide to go with a spindle I am going to have a 220v circuit installed.
    15362
    Re: spindle and VFD
    Make sure you do a 4 wire if you do it ( 2 ) Hot wires, Neutral and Ground that way you can have 120V and 240v from the same supply, most good electricians would know to do this, or if you do it yourself which you can do
    Mactec54
    Jul 2005
    7
    Re: spindle and VFD
    I will relay that information to my electrician.
    Jul 2005
    7
    Re: spindle and VFD
    I received my refund today. No problems. I consider this matter closed.
  1. Replies: 3
    Last Post: 10-19-2018, 05:12 PM
  2. Replies: 35
    Last Post: 03-21-2017, 02:29 PM
  3. Replies: 6
    Last Post: 03-20-2017, 09:30 PM
  4. Replies: 39
    Last Post: 01-09-2017, 06:26 AM
  5. Replies: 5
    Last Post: 07-19-2013, 05:16 AM
