586,042 active members*
3,668 visitors online*
Thread: Mazak M2
    Jan 2019
    Mazak M2
    Does Bobcad have a post processor to work with a M2 control on a 4 axis mill ? Also do they offer the comunications cable to do this ?
    Jun 2008
    1838
    Re: Mazak M2
    What Post Procesor are you currently using??
    Attached is the latest Mazatrol M2 PP, it is configured to use an "A" axis rotary 4th axis.
    BobCAD-CAM does not have a built in DNC for uploading or drip feeding to the Mazatrol control, you would need either the Predator Level 2 that you may have depending on the version of BobCAD you have, or another sofware like "Easy DNC" for example.
    Hope this helps
    Regards
    Rob
    Attached Files Attached Files
  1. Mazak MYSTERY. HOW do you clear this ANNOYING Mazak alarm??!!! NOBODY KNOWS!!
    By Mill&Lathe in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-03-2022, 01:55 AM
  2. Mazak QT-10 T2 manuals --acct w/ mazak?
    By CDTINC in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-21-2012, 05:09 AM
  3. mazak T-PLUS
    By windpirate in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-02-2010, 02:45 PM
  4. Mazak 6pc with machine Mazak 400n
    By anva in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-17-2010, 08:30 AM
  5. Mazak QT-200,Mazak VTC-160A,Mazak FJV-250 all pcb problem
    By sting_dot in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-22-2007, 02:20 AM
