586,384 active members*
3,605 visitors online*
Thread: Shim Stock
    Sep 2005
    1740
    Shim Stock
    Well I have finally used up the shim stock (stainless steel) that I had collected over the years and time to purchase more. Where is a current source that won't break the bank! And yikes I have looked at Amazon, gee If I knew it was that expensive I would have gathered more bits and pieces for my retirement!!
    Dec 2013
    5717
    Re: Shim Stock
    Try McMaster https://www.mcmaster.com/shim-stock
    I also buy Harbor Freight feeler gauge sets for about $5 https://www.harborfreight.com/feeler...-pc-63665.html I bought a half dozen sets a while back, great for shimming lathe tools and other uses that require about 1/2x4 shims.
    Jim Dawson
    Sandy, Oregon, USA
    Sep 2005
    1740
    Re: Shim Stock
    Thanks for the tip Jim and that's source for sure. I did find enough in my on hand stock to get the job done. When your 75 or so, you don't have that many shimming and setup jobs left to do
    Dec 2013
    5717
    Re: Shim Stock
    Quote Originally Posted by wmgeorge View Post
    I just turned 70 so I'm not too far behind you
    Jim Dawson
    Sandy, Oregon, USA
    Apr 2016
    841
    Re: Shim Stock
    Me too. I turn 70 in November. Retirement is great! Although I sometimes have so many projects I don't know where to turn next, I don't miss the pressure cooker I worked in.
    Gary
  1. Shim Stock Machining/Forming Options
    By cmnewcomer in forum MetalWork Discussion
    Last Post: 03-12-2020, 05:24 PM
  2. Replies: 5
    Last Post: 12-11-2017, 09:44 PM
  3. How do you shim your spindle?
    By CNC-Dude in forum Tormach Personal CNC Mill
    Last Post: 03-15-2015, 08:20 PM
  4. Looking for 718 inconel shim stock .004" thick.
    By surfit in forum MetalWork Discussion
    Last Post: 02-08-2014, 02:54 AM
  5. Advice for cutting .002" shim stock w/ endmill
    By stipierreinc in forum Uncategorised MetalWorking Machines
    Last Post: 01-29-2009, 04:19 PM
