586,035 active members*
3,790 visitors online*
    Exclamation Bodor BCL-1309X Laser Engrave issues.
    Hey Guys,
    Im currently having an issue with my laser that i can not fix.
    The cut seems to be okay, however the engraving is not where it should be. The further to the right of the machine the cut is the further right the engraving shifts and the same on the left i.e. when i start the cut on the left the engraving shifts to the left of where it should be. (Photos should be attached)
    Ive tried the file on a friends laser (exactly the same model) and it cuts perfect. Ive also re-uploaded the file to no avail. Most of the cutting is in alignment, however there are some smaller areas where the cut as well is not lined up.
    Here are some of the things i have tried.
    - Updating the user settings to match my friends laser, this brought everything closer but its still off
    - Followed the video on youtube about backlash and hasnt really made a difference.
    - Re-aligned starting from the bulb
    Ive played with all sorts of settings but am not getting any closer.
    Does anyone have any hints or tips on what to check next ?
    James
    Sep 2018
    83
    Re: Bodor BCL-1309X Laser Engrave issues.
    How is your Y belt tension looking?
    All belt tensions seem fine :/
    Dec 2018
    21
    Hello James, did you ask Bodor for help? I send a friend request to you. I can help you deal with it.
    Jan 2019
    5
    Laser anc cnc router supplier from china
    www.queencnc.com
    wehcat/whatsapp:+86 18254165298
    email:[email protected]
  1. Anyone here have a Bodor laser cutter?
    By AdrianPage in forum BODOR Laser
    Last Post: 08-13-2020, 03:53 PM
  2. Bodor USA Demo Laser
    By iGAK in forum BODOR Laser
    Last Post: 07-26-2018, 07:06 PM
  3. CO2 Laser Bodor
    By julianjaimes1985 in forum Laser Hardware
    Last Post: 07-24-2018, 10:02 AM
  4. Can't figure out how to engrave with RDworksV8 Bodor laser
    By AdrianPage in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-16-2018, 08:20 PM
