586,121 active members*
3,588 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Arduino > GRBL 1.1 Stepper motor won't move
Page 2 of 3 123
Results 21 to 40 of 41
  1. #21
    Re: GRBL 1.1 Stepper motor won't move
    Hi ,
    I finally convinced Chinese guy to resend a new board. Before doing this i bought a new ardunio uno and cnc shield with a4988 (same chips on the board) stepper motor drivers. I ve tested motors . They dont have any problem and running properly . I have to prove this to seller. So he/she has to sent the a new board.
    i ll write that it was running properly or not when new board arrives me.
    Thank For Your Support and Sharing.
  2. #22
    Mar 2015
    410
    Nothing is so difficult to solve than a hardware problem if you don't have the tools to diagnose and some spare parts to exchange.
    I hope you get a new properly working board.
  3. #23
    Jun 2020
    10
    I've read this thread with great interest as I am experiencing the same problem, but with different symptoms. I'm using Grbl 1.1 on a Mega 2560 along with UGS. The stepper drivers are DM524T (StepperOnLine) The interface all seems to be working fine except I do not get any pulse outputs from the Arduino to the drivers. The driver requires inverse logic which I've set up ($2=7, $3=7). I've also verified this with logic probe and oscilloscope (i.e. the pulse output stays high all the time). I've tried various speed values as suggested in this post - nothing happens. I've also tested the drivers/steppers with a short test program and they all work fine. Here's the configuration:
    $0 = 10
    $1 = 25
    $2 = 7
    $3 = 7
    $4 = 0
    $5 = 0
    $6 = 0
    $10 = 1
    $11 = 0.010
    $12 = 0.002
    $13 = 0
    $20 = 0
    $21 = 0
    $22 = 0
    $23 = 0
    $24 = 25.000
    $25 = 500.000
    $26 = 250
    $27 = 1.000
    $30 = 1000
    $31 = 0
    $32 = 0
    $100 = 50
    $101 = 50
    $102 = 50
    $110 = 50
    $111 = 50
    $112 = 50
    $120 = 5
    $121 = 5
    $122 = 5
    $130 = 200
    $131 = 200
    $132 = 200
    Any ideas?
    Paul
  4. #24
    Mar 2015
    410
    My guess is you are using a shield (RAMPS) that has a different pin mapping. If so, you need to change some compiler options in file config.h and flash the mega using this modified version.
    In this Wiki is explained how to do this. Use the original grbl-mega version, not the version from this WiKi that is adjusted for a lathe!
    https://github.com/HuubBuis/grbl-L-Mega/wiki/Threading-setup-RAMPS#change-compiler-options
  5. #25
    Mar 2015
    410
    Inverting the step pulse $2 and the step direction $3 has no influence on "not stepping". If your drivers require inverted logic, changing the enable pin $4 from 0 to 1, could solve the problem. If the steppers are locked, even for a short time, at the end of the move, then try this.
    You probably can also use the logic probe to find the stepper pulse pins.
  6. #26
    Jun 2020
    10
    No, I am not using a shield - just the Mega 2560, following the pin out outlined in the grbl documentation. Changing $4 to 1 makes no difference.
  7. #27
    Mar 2015
    410
    delete the grbl directory in your libraries directory that is located in your sketch directory
    place the grbl mega directory in your libraries directory
    upload the sketch again.
    if that doesn't help, upload your grbl-mega files and configuration so that I can test them.
    I have tested the configuration you posted earlier using UGS and a grbl-mega (RAMPS) Y-axis only and that works ok.
    Do your steppers move according to the UGS screen?
    Did you download the original grbl-mega? https://github.com/gnea/grbl-Mega
  8. #28
    Jun 2020
    10
    A little history first ...
    I first installed the grbl (master) library via "sketch | include library | add ZIP Library". (I didn't put anything into the sketch folder). Then I compiled and uploaded the grlbLoader program. Of course, it didn't work at all because I then realized the grbl master library was for Mega328 only.
    More research online pointed me to the Mega2560 20170802 version (the same as the one in your link), which I uploaded via XLoader. This brings me to my current situation. It communicates with UGS, but does not control the steppers. And no, the UGS screen does not show movement.
  9. #29
    Jun 2020
    10
    Ok, I did manage to get the mega library loaded in the IDE. Sent to the Mega. Same situation - no pulses to X Y Z. Also, UGS does not show any moves. This is using Grbl Mega v1.1f, 20170802 release. What am I missing?
  10. #30
    Mar 2015
    410
    This is strange but it helps!
    The Arduino IDE is quit tricky if you have multiple versions of the same software. You have to remove all the previous grbl software (not just overwrite), install the latest GRBL-Mega version and flash the GRBL-Mega again. After flashing you have to configure the grbl controller again!
    Another problem maybe UGS masking information that it doesn't understand. You can open the Arduino terminal to the grbl controller and see the unfiltered status.
    Press the reset button on the grbl controller
    send a $I command for build information
    send a ? command for the current status.
    This is my output (after flashing and reconfiguring) from grbl (GRBL-L-Mega version)
    after reset:
    grbl 1.1g ['$' for help]
    after $i
    [VER:1.1g.20180813.Mega:]
    [OPT:VNM+,35,255]
    ok
    after ?
    <Idle|MPos:0.000,0.000,0.000|FS:0,0|WCO:0.000,0.00 0,0.000>
    ok
  11. #31
    Jun 2020
    10
    after reset:
    Grbl 1.1f [$ for help]
    after $i
    (nothing)
    after ?
    I don't get "ok" after the "?". I see you're using 1.1g - would that make a difference?
    I wonder if using XLoader may have caused a problem?
  12. #32
    Mar 2015
    410
    The good thing, it shows grbl is running and doesn't report any errors.
    If you flashed the last grbl-mega version, it should show 1.1g and i know you did set it up the right way.
    that should not make a difference
    I don't know but generally, if you need the same results, you need to follow the steps as asked.
    If you just uploaded an binary file, there is a great chance you get different results
    please flash the last grbl-mega version the way I asked!
    try the command
    G91 X10 F50
    after that, sent a ?
    you sould see grbl is running
    My test:
    ok
    G91 X10
    ok
    <Run|MPos:1.320,0.000,0.000|FS:50,0|Ov:100,100,100 >
    ok
    <Run|MPos:9.340,0.000,0.000|FS:50,0>
    ok
  13. #33
    Jun 2020
    10
    I did flash it the way you said. I only used XLoader the first time, a few months ago. Where do I get version 1.1g? I didn't find it in the link you gave me - only 1.1f.
  14. #34
    Jun 2020
    10
    Tried the commands - it stays at Idle.
  15. #35
    Mar 2015
    410
    Quote Originally Posted by paulp1m View Post
    I am not behind PC at the moment!
    Search for grbl mega on GitHub.
    I will look at the link later this evening
  16. #36
    Jun 2020
    10
    Tried a few things ...
    - swapped the Mega 2560 with a Mega 2560 R3 (starting from scratch)
    - flashed and ran a simple test program to prove wiring is correct - steppers run fine
    - flashed Grbl (via IDE, GrblLoader program)
    - updated/confirmed config data
    Using serial monitor with G91/G93 commands, the ? status always stays at idle and $I returns nothing. However, if I use UGS and turn on verbose - I see the Run status with G91 commands. I can also see the values change correctly ... BUT - the UGS position values stay at zero. Also, there are still no stepper pulses.
    - Un-installed Arduino and deleted the libraries and Program(x86) files.
    - Re-installed Arduino.
    - Copied the Mega 1.1F grbl folder to the sketch libraries folder.
    - Verified in Arduino that the grbl library existed (yes)
    - Re-flashed grbl (via IDE, GrblLoader program)
    Same results as above.
  17. #37
    Mar 2015
    410
    The link I provided is the grbl-mega site. On the page there is a green "Clone" button you can use to download a zip file containing the latest stable release.
    Depending on your wiring, it could be possible the reset pin is activated, which will reset the controller as soon as it starts up. Just run on a bare mega controller without any wires attached.
    After the receive of a command, the controller must response by sending OK so the sender knows the command is received and will be executed!
    Use the arduino terminal to see the respose of the controller.
  18. #38
    Jun 2020
    10
    Finally making forward progress. Flashed the latest mega (1.1g) and I got the expected responses from the terminal:
    $I
    [OPT:VNM+,35,255]
    OK
    Also see pulses now on the scope. Turns out the values for $100... were way to small too show up reliably on a scope, and far too spread out to effect any noticeable change in the stepper. I can now hook up all the wiring again - should work.
    UGS still doesn't report the machine status / position. I'm using version 1.06.
    Almost there ...
  19. #39
    Mar 2015
    410
    These low values are to prevent stalling the stepper, just to make sure the stepper will turn when receiving a pulse. If you set the scope trigger to normal, the scope will catch these pulses. If your driver has leds on it, like mine, you can see the leds go on and off.
    There are 2 kinds of UGS programs, classic and platform. I use platform version 2.0 great to hear things start working for you.
    Have fun,
    Huub
  20. #40
    Jun 2020
    10
    It's an old o-scope and has seen better days (like the owner ...). The DM542T driver doesn't have LEDs - wish they did now.
    I'm going to switch to UGS Platform.
    Thanks so much for your help!
    Paul
Page 2 of 3 123
  1. Help! Mach 3 Won't Move my Stepper Motor - Emergency Stop Mode
    By AntonCNC in forum Machines running Mach Software
    Last Post: 03-08-2017, 02:38 AM
  2. my stepper motor NEMA 23 do not move but make a little noise
    By envergure in forum Stepper Motors / Drives
    Last Post: 05-16-2016, 05:40 AM
  3. Replies: 9
    Last Post: 12-29-2014, 05:36 AM
  4. Stepper motor move barely!need help
    By mike3385 in forum Mach Lathe
    Last Post: 09-27-2010, 03:48 PM
  5. How to you make a stepper motor move?
    By HereinCS in forum DIY CNC Router Table Machines
    Last Post: 08-24-2010, 06:45 AM
