586,060 active members*
4,525 visitors online*
IndustryArena Forum > CAM Software > Alphacam > Alphacam 2015 - Importing DXF geometry into specific layer - how to?
Results 1 to 2 of 2
    Jan 2019
    Question Alphacam 2015 - Importing DXF geometry into specific layer - how to?
    Trying to import a DXF geometry into a specific user layer. When I use import, even with the desired layer marked active, it places the geometry in a new layer at the bottom. Can't find any useful information online.
    I appreciate any insight.
    -Nikki
    May 2016
    Re: Alphacam 2015 - Importing DXF geometry into specific layer - how to?
    Hi, name the layer from the .dxf file exactly like in Alphacam layer. Example: If you have in Alphacam a layer named CONTOUR you should name the layer from AUTOCAD also CONTOUR. When you will import the .dxf file it will be inserted in the Alphacam CONTOUR layer.
